Lenovo ThinkCentre M720t MT i5-8400 4GB 1TB Win 10 Pro
Up to £75 Cashback available!
Quicklinx: F2QFWS00 Mfr#: 10SQ002HUK
Processor Type: Core i5
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB
Hard Drive Capacity: 1TB
Storage Type: HDD
  • Core i5
Hurry, only 2 left in stock!
£408.39 ex VAT
£490.06 inc VAT
Powerful and secure, the ThinkCentre M720 Tower lets you multi-task seamlessly and lets your productivity flow. As well as cutting-edge processing, memory, and storage, it comes with advanced data and hardware security as standard. Easy to manage, this performance-enhancing PC is designed to drive your business forward.
  • Real power, real results
    The ThinkCentre M720 Tower is designed to help you get what you need done, quickly and efficiently. Powered by an Intel processor and lightning-fast DDR4 memory, it takes everything in its stride - from everyday computing, to high-end graphic design and multitasking, to data-crunching.
  • Send would-be hackers packing
    To help safeguard your data, Smart USB Protection and the Trusted Platform Module (TPM) are hardwired into every ThinkCentre M720. The first enables you to restrict what USB devices can access your PC, while the TPM is the international standard for encrypting data.
  • It pays to be well connected
    When it comes to connecting your computing accessories and smart devices, the ThinkCentre M720 Tower has more than enough ports, including USB-C and USB 3.1 ports. What's more, these high-speed ports are conveniently located in the front for quick, easy access.
  • Easy to use & configure
    If the PC is under the desk or slightly out of reach, you can switch it on remotely with a simple shortcut using the keyboard, Alt + P. The ThinkCentre M720 Tower also has a number of expansion slots, enabling it to be configured as your business needs change.
Lenovo ThinkCentre M720t - tower - Core i5 8400 2.8 GHz - 4 GB - 1 TB - UK
Personal computer - tower
1 x Intel Core i5 (8th Gen) 8400 / 2.8 GHz (4 GHz) (6-core)
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
4 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Card Reader
7 in 1
Graphics Controller
Intel UHD Graphics 630
GigE
Keyboard
OS Provided
15 cm x 27.05 cm x 36 cm
7 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
Tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel B360
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
4 GB / 64 GB (max)
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
Optical Storage
DVD-Writer
Card Reader
7 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
Max Monitors Supported
3
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
USB
Ethernet Controller
Intel I219-V
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5" x 1/3H
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x1 - half-length, full-height , 2 (total) / 2 (free) x M.2 Card
2 x USB 3.1 Gen 2 (2 in front) , 2 x USB 3.1 Gen 1 (2 in front) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 4 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 2 x DisplayPort , 1 x audio line-out
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
Security Slot Type
Kensington security slot
RoHS, Energy-Related Products (ErP) Lot 3, TUV Rheinland Low Noise Certification
TopSeller
Power supply
Nominal Voltage
Power Provided
180 Watt
Efficiency
85%
Operating System / Software
OS Provided
Software
Cyberlink PowerDVD, CyberLink Power2Go, Linkedin, Lenovo ThinkVantage
ENERGY STAR Certified
ENERGY STAR Version
6.1
15 cm
27.05 cm
36 cm
7 kg
Lenovo ThinkCentre M720t MT i5-8400 4GB 1TB Win 10 Pro Bundle deal on Lenovo ThinkCentre M720t MT i5-8400 4GB 1TB Win 10 Pro
£590.55
saving £8.33
£507.56
Keyboards and Mice (1)
F2QF Lenovo Optical 3-button W/Mouse USB In Stock £12.69
Other bundles (1)
F2QF Lenovo Microsaver Security Cable Lock In Stock £34.15
Storage Type: HDD
Processor Model: I5-8400
Type: Personal computer
Case Style: Tower
Optical Storage: DVD-Writer
Brand: Lenovo
Price Range Ex VAT: 300 - 500
