Lenovo ThinkCentre M720s i5-8400 8GB 256GB Win10 Pro
Quicklinx: F2BLWS00 Mfr#: 10ST0031UK
  • Core i5
  • IEEE 802.11n
Powerful yet compact, the ThinkCentre M720 SFF boasts Intel processing with advanced memory, storage and USB technology, enabling you to multi-task seamlessly. To help safeguard your data and hardware, multiple security features are built in. Easy to manage and configure, this high-performance PC can meet your business needs now and in the future.
  • Real power, real results
    The ThinkCentre M720 SFF is designed to help you get what you need done, quickly and efficiently. Powered by an Intel processor and lightning-fast DDR4 memory, it takes everything in its stride - from everyday computing, to high-end graphic design and multitasking, to data-crunching.
  • Go green, save green
    With its Energy Star 7.0 and EPEAT Gold rating, the ThinkCentre M720 SFF is proven to be extremely energy efficient. In addition, it also has been rigorously tested.
Lenovo ThinkCentre M720s - SFF - Core i5 8400 2.8 GHz - 8 GB - SSD 256 GB - UK
Personal computer - small form factor
Intel Core i5 (8th Gen) 8400 / 2.8 GHz (4 GHz) (6-core)
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - SATA 6Gb/s - 2.5" - TCG Opal Encryption
Optical Storage
No optical drive
Card Reader
7 in 1
Graphics Controller
Intel UHD Graphics 630
GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Linkedin, Lenovo ThinkVantage
9.25 cm x 29.05 cm x 34.35 cm
6 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
Small form factor
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.8 GHz
Max Turbo Speed
4 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel B360
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 64 GB (max)
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - 2.5"
1 x 256 GB
Interface Type
SATA 6Gb/s
TCG Opal Encryption
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
Optical Storage
No optical drive
Card Reader
7 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
Max Monitors Supported
3
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
USB
Ethernet Controller
Intel I219-V
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 3165
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Wake on LAN (WoL)
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" x 1/3H
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 2 (total) / 2 (free) x PCIe 3.0 x1 - low-profile , 2 (total) / 1 (free) x M.2 Card
2 x USB 3.1 Gen 2 (2 in front) , 2 x USB 3.1 Gen 1 (2 in front) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 4 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 2 x DisplayPort , 1 x audio line-out
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
Security Slot Type
Kensington security slot
RoHS, Energy-Related Products (ErP) Lot 3
TopSeller
Power supply
Power Provided
180 Watt
Efficiency
85%
Operating System / Software
OS Provided
Software
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.1
9.25 cm
29.05 cm
34.35 cm
6 kg
