Lenovo ThinkCentre M715Q USFF AMD A10 8GB 256GB SSD Win10 Pro
Quicklinx: D11FWS00 Mfr#: 10M3000LUK
  • AMD Radeon R7
  • IEEE 802.11n
  • Bluetooth 4.0
The rugged and powerful ThinkCentre M700 Tiny can handle tough treatment, including dusty environments while boasting cutting edge features in an astonishingly compact form factor.
  • Optimized for the future
    With a powerful processor and advanced memory, the ThinkCentre M715q is designed to meet your computing needs now - and in the future. It's also built to military specifications and able to withstand punishing treatment, including humidity, extreme temperatures, and dust. In short, it won't let you down.
  • PC performance at an affordable cost
    The ThinkCentre M715q can do everything a full-fledged PC can do - from data analytics to video conferencing. And by enabling you to access files, apps, and services through the cloud, it gives your business more freedom and flexibility. Yet, with far fewer components than a regular PC, such as less storage, it's less expensive and has a longer life span.
  • Compact and versatile
    Compact in volume, the ThinkCentre M715q is compact enough to fit virtually anywhere. This sleek device is also extremely versatile. Slip it into the back of a ThinkCentre Tiny-In-One, for instance, to create a modular, secure all-in-one PC instantly.
  • Business-ready, right out of the box
    With a host of ports, including USB 3.0, VGA, and HDMI, there's plenty of room for all your computing peripherals. You can also connect up to three monitors to expand workspace, making navigation between applications easier and improving productivity.
Lenovo ThinkCentre M715q - tiny - A10 9700E 3 GHz - 8 GB - SSD 256 GB - UK
Personal computer - tiny
AMD A10 9700E / 3 GHz (, up to 3.5 GHz, (Quad-Core)
Processor Main Features
AMD Turbo CORE Technology
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - NVM Express (NVMe)
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R7
Audio Output
Stereo
1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
ThinkVantage Tools, Lenovo Companion, Lenovo ID
17.9 cm x 18.29 cm x 3.45 cm
1.3 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
Tiny
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
AMD A10 9700E
Clock Speed
3 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
AMD B300
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express 3.0 x4
NVM Express (NVMe)
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R7
Video Interfaces
VGA, DisplayPort
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Scroll
Ethernet Controller
Realtek RTL8111EPV
Wireless LAN Supported
Wireless NIC
Realtek RTL8821AE
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Wake on LAN (WoL)
DASH 1.1
Slots
2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU
3 x USB 3.0 (2 in front) (one of them is Always On and fast-charging) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 3 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort , 1 x headphones , 1 x VGA
VESA mounting kit
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
TopSeller
Power adapter
Power Provided
65 Watt
Efficiency
88%
Operating System / Software
OS Provided
Software
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.1
17.9 cm
18.29 cm
3.45 cm
1.3 kg
