The rugged and powerful ThinkCentre M700 Tiny can handle tough treatment, including dusty environments while boasting cutting edge features in an astonishingly compact form factor.
Optimized for the future
With a powerful processor and advanced memory, the ThinkCentre M715q is designed to meet your computing needs now - and in the future. It's also built to military specifications and able to withstand punishing treatment, including humidity, extreme temperatures, and dust. In short, it won't let you down. -
PC performance at an affordable cost
The ThinkCentre M715q can do everything a full-fledged PC can do - from data analytics to video conferencing. And by enabling you to access files, apps, and services through the cloud, it gives your business more freedom and flexibility. Yet, with far fewer components than a regular PC, such as less storage, it's less expensive and has a longer life span. -
Compact and versatile
Compact in volume, the ThinkCentre M715q is compact enough to fit virtually anywhere. This sleek device is also extremely versatile. Slip it into the back of a ThinkCentre Tiny-In-One, for instance, to create a modular, secure all-in-one PC instantly. -
Business-ready, right out of the box
With a host of ports, including USB 3.0, VGA, and HDMI, there's plenty of room for all your computing peripherals. You can also connect up to three monitors to expand workspace, making navigation between applications easier and improving productivity.
- Lenovo ThinkCentre M715q - tiny - A10 9700E 3 GHz - 8 GB - SSD 256 GB - UK
- Personal computer - tiny
- Localisation
- Processor
- AMD A10 9700E / 3 GHz (, up to 3.5 GHz, (Quad-Core)
- Processor Main Features
- AMD Turbo CORE Technology
- Cache Memory
- 2 MB L2 Cache
- Cache Per Processor
- 2 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - NVM Express (NVMe)
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon R7
- Audio Output
- Stereo
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- ThinkVantage Tools, Lenovo Companion, Lenovo ID
- Black
- 17.9 cm x 18.29 cm x 3.45 cm
- 1.3 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Tiny
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- AMD A10 9700E
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- AMD B300
Cache Memory
- Installed Size
- L2 Cache - 2 MB
- 2 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R7
- Video Interfaces
- VGA, DisplayPort
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Scroll
- Ethernet Controller
- Realtek RTL8111EPV
- Wireless LAN Supported
- Wireless NIC
- Realtek RTL8821AE
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Wake on LAN (WoL)
- DASH 1.1
- Slots
- 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU
- 3 x USB 3.0 (2 in front) (one of them is Always On and fast-charging) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 3 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort , 1 x headphones , 1 x VGA
- Included Accessories
- VESA mounting kit
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
- TopSeller
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 88%
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 17.9 cm
- 18.29 cm
- 3.45 cm
- 1.3 kg
