Lenovo ThinkCentre M710e SFF Intel Core i3 7100 8GB 1TB Windows 10
Quicklinx: DP5HWS00 Mfr#: 10UR0032UK
Processor Type: Core i3
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 1TB
Storage Type: HDD
  • Core i3
More than 50 in stock
£422.51 ex VAT
£507.01 inc VAT
  • An IT admin's dream
    The ThinkCentre M710e features a tool-free chassis, which means that if IT admins ever need access, it's sure to be quick and easy. The M710e delivers powerful security options that safeguard your organization's data. With Trusted Platform Module (TPM) firmware, data is encrypted. Smart USB protection enables ports to be individually defined and blocked, so would-be thieves are thwarted if they try to download information. Plus smart cable block enables locking of all wired peripherals that are attached to the M710e - once the block is clipped on, it can only be removed from the inner side of the chassis. What more could an IT administrator ask for!
  • Big on power
    Powered by the excellent processor, the ThinkCentre M710e SFF is designed for speed, responsiveness, and efficiency - three key features that can help propel your business.
  • Lock slots for physical security
    The M710e features lock slots for physical security too: a pad lock slot prevents removal of the back cover, while a Kensington lock slot enables it to be secured to a workstation.
Lenovo ThinkCentre M710e - SFF - Core i3 7100 3.9 GHz - 8 GB - 1 TB - UK
Personal computer - small form factor
1 x Intel Core i3 (7th Gen) 7100 / 3.9 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Card Reader
7 in 1
Graphics Controller
Intel HD Graphics 630
GigE
Keyboard
OS Provided
10 cm x 30.35 cm x 27.35 cm
4.25 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site
Personal computer
Product Form Factor
Small form factor
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel B250
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
2
Optical Storage
DVD-Writer - SATA
Card Reader
7 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
Max Monitors Supported
2
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Mouse Name
Lenovo Calliope Mouse
USB
Ethernet Controller
Realtek RTL8111HN
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" x 1/3H
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x1 - low-profile , 2 (total) / 2 (free) x M.2 Card
4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x microphone , 1 x headphones/microphone (1 in front) , 2 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x audio line-out
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
Security Slot Type
Kensington security slot
RoHS, WEEE, Energy-Related Products (ErP) Lot 3
TopSeller
Power supply
Nominal Voltage
Power Provided
180 Watt
Efficiency
85%
Operating System / Software
OS Provided
ENERGY STAR Certified
ENERGY STAR Version
6.1
10 cm
30.35 cm
27.35 cm
4.25 kg
Shipping Width
19.5 cm
Shipping Depth
39 cm
Shipping Height
50 cm
Shipping Weight
6.45 kg
Lenovo ThinkCentre M710e SFF Intel Core i3 7100 8GB 1TB Windows 10 Bundle deal on Lenovo ThinkCentre M710e SFF Intel Core i3 7100 8GB 1TB Windows 10
£607.73
saving £8.33
£521.68
Keyboards and Mice (1)
DP5H Lenovo Optical 3-button W/Mouse USB In Stock £13.60
Other bundles (1)
DP5H Lenovo Microsaver Security Cable Lock In Stock £23.87
Storage Type: HDD
Processor Model: I3-7100
Type: Personal computer
Case Style: Desktop
Optical Storage: DVD-Writer
Brand: Lenovo
Price Range Ex VAT: 300 - 500
