The ThinkCentre M710e small form factor doesn't scrimp on performance. Super compact, this entry-level PC offers robust security features to safeguard your data, powerful performance with high processing, and improved platform stability.
An IT admin's dream
The ThinkCentre M710e features a tool-free chassis, which means that if IT admins ever need access, it's sure to be quick and easy. The M710e delivers powerful security options that safeguard your organization's data. With Trusted Platform Module (TPM) firmware, data is encrypted. Smart USB protection enables ports to be individually defined and blocked, so would-be thieves are thwarted if they try to download information. Plus smart cable block enables locking of all wired peripherals that are attached to the M710e - once the block is clipped on, it can only be removed from the inner side of the chassis. What more could an IT administrator ask for! -
Big on power
Powered by the excellent processor, the ThinkCentre M710e SFF is designed for speed, responsiveness, and efficiency - three key features that can help propel your business. -
Lock slots for physical security
The M710e features lock slots for physical security too: a pad lock slot prevents removal of the back cover, while a Kensington lock slot enables it to be secured to a workstation.
- Lenovo ThinkCentre M710e - SFF - Core i5 7400 3 GHz - 8 GB - HDD 1 TB - UK
- Personal computer - small form factor
- Localisation
- Processor
- Intel Core i5 (7th Gen) 7400 / 3 GHz (, up to 3.5 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- 7 in 1
- Graphics Controller
- Intel HD Graphics 630
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Black
- 10 cm x 30.35 cm x 27.35 cm
- 4.25 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel B250
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 2
Optical Storage
- DVD-Writer - SATA
Card Reader
- 7 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- Max Monitors Supported
- 2
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- Lenovo Calliope Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111HN
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" x 1/3H
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x1 - low-profile , 1 (total) / 1 (free) x M.2 Card
- 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x microphone , 1 x headphones/microphone (1 in front) , 2 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x audio line-out
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
- Security Slot Type
- Kensington security slot
- RoHS, WEEE, Energy-Related Products (ErP) Lot 3
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- Efficiency
- 85%
Operating System / Software
- OS Provided
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 10 cm
- 30.35 cm
- 27.35 cm
- 4.25 kg
- Shipping Width
- 19.5 cm
- Shipping Depth
- 39 cm
- Shipping Height
- 50 cm
- Shipping Weight
- 6.45 kg
