Whether you run a small business or the IT department of a massive enterprise, you can have confidence in these desktop PCs' reliability, ease of use and productivity - not to mention their green appeal. Choose from multiple form factors, then let these tools of business do the rest.
Liberate your workspace
ThinkCentre M all-in-one combines enhanced user experience, uncompromised computing power, and long-term stability, coupled with greater space-saving and energy-efficient features. Ideal for crowded work areas, the ThinkCentre M all-in-one integrates the monitor with the central PC unit, giving you more room to work. -
Powered for productivity
Equipped with the visibly smart processor, featuring an outstanding performance for your demanding tasks. It optimizes multitasking with multiple windows in one screen on your desktop - like hooking up to multiple monitors. -
Integrated Wi-Fi connectivity
USB 3.0 port transfers files faster - especially useful when copying large media files. Plus, you can increase your power supply with the ability to charge external devices quickly. It supports dual independent display to expand your virtual desktop and multiply productivity. -
IT cost savings and convenience
An aging PC fleet can inflate maintenance costs and divert IT resources from more important tasks. Easy-to-manage ThinkCentre desktop helps free up your IT team while reducing overhead - and saving time. -
Enterprise-level security
Protect your business-critical data. The exclusive ThinkVantage Client Security works in conjunction with an embedded chip called the Trusted Platform Module (TPM) to manage encryption keys and processes for enhanced security.
- Lenovo ThinkCentre M700z - all-in-one - Core i3 6100T 3.2 GHz - 4 GB - HDD 500 GB - LED 20" - UK
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i3 (6th Gen) 6100T / 3.2 GHz (Dual-Core)
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- 9 in 1
- Monitor
- 20" - LED - 1600 x 900 (HD+) - 16:9
- Graphics Controller
- Intel HD Graphics 530
- Camera
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software Included
- ThinkVantage Rescue and Recovery, Adobe Reader, ThinkVantage System Update, Lenovo Password Manager, Lenovo Message Center Plus, ThinkVantage Tools, Lenovo Solution Center, McAfee LiveSafe (30 days trial), Lenovo Desktop Power Manager, SHAREit, REACHit, Lenovo Bluetooth Lock, PowerDVD Create
- Business black
- 50.3 cm x 24.5 cm x 40 cm
- 6.77 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- All-in-one - with monitor stand
- Built-in Devices
- Stereo speakers
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Business black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.2 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD-Writer - SATA
Card Reader
- 9 in 1 card reader
Monitor
- Monitor Type
- LED
- Diagonal Size
- 20"
- Native Resolution
- 1600 x 900 (HD+)
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- Dolby Audio Optimization, High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 1 Megapixel
- Resolution
- 720p
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
Audio Input
- Microphone
- Interface (Bus) Type
- M.2 Card
- Ethernet Controller
- Realtek RTL8111G
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8260
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- Wake on LAN (WoL)
- Slots
- 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU
- 2 x USB 3.0 , 1 x headphones/microphone - mini-jack , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 4 x USB 2.0
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion switch
- VESA Mounting Interface
- 100 x 100 mm
- RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
- TopSeller
- Power adapter
- Voltage Required
- Power Provided
- 120 Watt
- Efficiency
- 89%
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 50.3 cm
- 24.5 cm
- 40 cm
- 6.77 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
