ThinkCenter M700 Tiny is an ultrasmall form factor. It offers mounting solutions, including support for standard VESA mounts and Tiny-in-One configurations - which transform your PC into a space-saving modular all-in-one. Tiny desktops fit just about anywhere, while still delivering reliable, enterprise-level performance.
Maximize productivity with independent display support for up to three monitors. The expanded work area and easier navigation between applications help reduce errors and improve productivity as you extend your desktop across multiple monitors.
Tiny form factor
ThinkCenter M700 Tiny is an ultrasmall form factor. Tiny desktops fit just about anywhere, while still delivering reliable, enterprise-level performance. -
Multiple monitor support
Maximize productivity with independent display support for up to three monitors. The expanded work area and easier navigation between applications help reduce errors and improve productivity as you extend your desktop across multiple monitors. -
Keyboard power-on support
If you choose to mount this compact unit on the back of your monitor, you can still power on conveniently from the front, by simply pressing Alt+P on a USB-connected keyboard. Also compatible with wireless keyboards. -
Fast data transfer
Move data between the M700 Tiny and other devices quickly with USB 3.0 - it's up to 10 times faster than previous USB technologies, and is backward-compatible. -
Tested to military specifications
Military-specification testing validates the ruggedness, durability, and quality of this PC by testing against multiple parameters.
- Lenovo ThinkCentre M700 - tiny - Core i3 6100T 3.2 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - tiny
- Localisation
- Processor
- Intel Core i3 (6th Gen) 6100T / 3.2 GHz (Dual-Core)
- Processor Main Features
- Hyper-Threading Technology
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 530
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- ThinkVantage Tools, Lenovo Solution Center, Lenovo Companion, McAfee LiveSafe (30 days trial), Lenovo Desktop Power Manager, SHAREit, REACHit, Lenovo QuickOptimizer
- Black
- 17.9 cm x 18.29 cm x 3.45 cm
- 1.3 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Tiny
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.2 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel B150
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Preferred Pro USB
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I219-LV
- Data Link Protocol
- Wake on LAN (WoL)
- Slots
- 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU
- 6 x USB 3.0 (2 front, 4 rear) (one of them is Always On) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort , 1 x microphone (1 in front) , 1 x headphones
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
- RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
- TopSeller
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 88%
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- 17.9 cm
- 18.29 cm
- 3.45 cm
- 1.3 kg
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
