Lenovo ThinkCentre M630e Tiny Intel Core i5-8265U 8GB 256GB SSD Windows 10 Professional 64-bit
Quicklinx: FG9YWS00 Mfr#: 10YM003BUK
Processor Type: Core i5
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
Storage Type: SSD
  • Core i5
11 in stock
£469.43 ex VAT
£563.31 inc VAT
It's a small PC, but you can use it to get big things done. Solid specs including powerful processing, large memory and multiple storage options make the ThinkCentre M630e Tiny a compact powerhouse. The ThinkCentre ecosystem gives you extraordinary flexibility. Easy-to-install accessories let you attach your M630e Tiny to a projector, a wall, or the underside of a desk. You can also create your own modular AIO with a ThinkCentre Tiny-in-One monitor. Added benefit: you can save on costs by upgrading the display and the M630e Tiny on separate schedules.
The ThinkCentre M630e Tiny helps you keep your business data safe with security features like Smart USB Protection, which prevents malware from entering your system through the USB ports. A menu of I/O ports give you high-speed connectivity to peripherals for easy multitasking. And a USB-C data port makes it a snap to share information quickly. IT admins will love the Smart Power On feature, which enables remote device manageability with a simple keyboard shortcut.
  • Big on performance
  • Tiny by design
  • Robust security
  • Versatile connectivity
Lenovo ThinkCentre M630e - tiny - Core i5 8265U 1.6 GHz - 8 GB - SSD 256 GB - UK
Personal computer - tiny
Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) (Quad-Core)
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - TCG Opal Encryption, NVM Express (NVMe)
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 620
GigE, 802.11ac, Bluetooth 4.2
Keyboard
OS Provided
17.9 cm x 18.29 cm x 3.45 cm
1.32 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site
Personal computer
Product Form Factor
Tiny
Built-in Devices
Speaker
Embedded Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 16 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
1 (Total) / 0 (empty)
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express 3.0 x4
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Max Monitors Supported
2
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Lenovo Calliope Keyboard
USB
Localization & Layout
Mouse
Mouse Name
Lenovo Calliope Mouse
USB
Ethernet Controller
Realtek RTL8111HN-CG
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 3165
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac, Bluetooth 4.2
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
2 (total) / 0 (free) x M.2 Card
3 x USB 3.1 Gen 1 (1 front, 2 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x HDMI
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion switch
Security Slot Type
Kensington security slot
RoHS, WEEE, REACH, Energy-Related Products (ErP) Lot 3
TopSeller
Power adapter
Nominal Voltage
Power Provided
65 Watt
Efficiency
88%
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Lenovo Vantage, Linkedin
ENERGY STAR Certified
ENERGY STAR Version
7.0
17.9 cm
18.29 cm
3.45 cm
1.32 kg
Lenovo ThinkCentre M630e Tiny Intel Core i5-8265U 8GB 256GB SSD Windows 10 Professional 64-bit Bundle deal on Lenovo ThinkCentre M630e Tiny Intel Core i5-8265U 8GB 256GB SSD Windows 10 Professional 64-bit
£568.60
FG9Y Lenovo Optical 3-button W/Mouse USB In Stock £13.83
Storage Type: SSD
Processor Model: I5-8265U
Type: Personal computer
Case Style: Ultra small form factor
Optical Storage: None
Brand: Lenovo
Price Range Ex VAT: 300 - 500
