Lenovo ThinkCentre M630e Tiny Intel Core i3-8145U 4GB 128GB SSD Windows 10 Professional 64-bit
Quicklinx: FG9WWS00 Mfr#: 10YM0008UK
  • Core i3
  • IEEE 802.11n
  • Tiny by design
    The ThinkCentre ecosystem gives you extraordinary flexibility. Easy-to-install accessories let you attach your M630e Tiny to a projector, a wall, or the underside of a desk.
  • Robust security
    The ThinkCentre M630e Tiny helps you keep your business data safe with security features like Smart USB Protection, which prevents malware from entering your system through the USB ports.
  • Versatile connectivity
    A menu of I/O ports gives you high-speed connectivity to peripherals for easy multitasking. And a USB-C data port makes it a snap to share information quickly. IT admins will love the Smart Power On feature, which enables remote device manageability with a simple keyboard shortcut.
  • Heavy-duty durability
    Rigorous testing ensures the ThinkCentre M630e Tiny is built to last. Using it outside a clean office workspace? The optional Dust Shield protects internal components for reliability over the long haul.
Lenovo ThinkCentre M630e - tiny - Core i3 8145U 2.1 GHz - 4 GB - SSD 128 GB - UK
Personal computer - tiny
Intel Core i3 (8th Gen) 8145U / 2.1 GHz (3.9 GHz) (Dual-Core)
Cache Memory
4 MB
Cache Per Processor
4 MB
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 128 GB - SATA 6Gb/s - 2.5"
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 620
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
17.9 cm x 18.29 cm x 3.45 cm
1.32 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site
Personal computer
Product Form Factor
Tiny
Built-in Devices
Speaker
Embedded Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
4 MB
Cache Per Processor
4 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
1 (Total) / 0 (empty)
Configuration Features
1 x 4 GB
Hard Drive
SSD - 2.5"
1 x 128 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Max Monitors Supported
2
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Lenovo Calliope Keyboard
USB
Localization & Layout
Mouse
Mouse Name
Lenovo Calliope Mouse
USB
Ethernet Controller
Realtek RTL8111HN-CG
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 3165
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
2 (total) / 1 (free) x M.2 Card
3 x USB 3.1 Gen 1 (1 front, 2 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x HDMI
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion switch
Security Slot Type
Kensington security slot
RoHS, WEEE, REACH, Energy-Related Products (ErP) Lot 3
TopSeller
Power adapter
Power Provided
65 Watt
Efficiency
88%
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Lenovo Vantage, Linkedin
ENERGY STAR Certified
ENERGY STAR Version
7.0
17.9 cm
18.29 cm
3.45 cm
1.32 kg
