Lenovo ThinkCentre Edge 72 3493 - Core i5-3330S - 4GB - 500GB - Win 7 / 8 Pro 64-bit downgrade
Quicklinx: 95CJWS00 Mfr#: RCFMDUK
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
Whether you manage a home office or a mid-sized business, the ThinkCentre Edge 72 Small Form Factor desktop is an excellent choice for everyday computing. From its productivity features to its multiple display support - which makes multitasking a breeze - the ThinkCentre Edge 72 helps you keep your business running smoothly and efficiently.
RapidBoot Performance
Lenovo's exclusive RapidBoot HDD Accelerator dramatically reduces startup time by copying and compressing Windows boot files and reloading them to RAM.
Multi-Display Support
ThinkCentre Edge 72 natively supports two independent displays - and permits up to four displays on models with discrete graphics.
System Stability
Proprietary software ensures system stability, simplifies maintenance, makes it easier to recover data when necessary, and manages your passwords.
Hardware Security
The Kensington Lock port makes maintaining asset security a snap.
Enhanced graphics
Enjoy rich screen resolution and vivid graphics - and view data across as many as four screens -with the optional AMD dual-port graphics card.
View Management Utility
Multitask with ease and maximize your productivity with the ThinkCentre Edge 72's View Management Utility. The VMU creates up to four partitions on a single display - it's like using multiple monitors in one.
WiFi, Bluetooth
With 802.11 b/g/n WiFi connectivity and optional Bluetooth® 4.0, you'll be able to connect seamlessly with your network and other devices.
Energy Efficient
Save on energy costs and help the environment with the ThinkCentre Edge 72's Cisco EnergyWise-certified Desktop Power Manager.
Data Transfer
The ThinkCentre Edge 72's 6 USB ports give you plenty of ways to transfer data and connect other devices.
Lenovo ThinkCentre Edge 72 - SFF - AI Ready - Core i5 3330S 2.7 GHz - 4 GB - HDD 500 GB
Personal computer - SFF AI Ready - administrator password, hard drive password, power-on password, boot without keyboard or mouse, USB port control, boot sequence control
Intel Core i5 (3rd Gen) 3330S / 2.7 GHz (, up to 3.2 GHz, (Quad-Core)
Processor Socket
LGA1155 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - PC3-12800
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
HDD 500 GB - SATA 3Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
9 in 1
Graphics Controller
Intel HD Graphics 2500
Audio Output
Stereo - integrated
1GbE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
Glossy black
33.6 cm x 38.2 cm x 10.1 cm
6 kg
Manufacturer Selling Program
TopSeller
Limited warranty - 1 year - on-site - response time: next business day
Personal computer - AI Ready
Product Form Factor
SFF
Built-in Devices
Speaker
Glossy black
Processor / Chipset
CPU
Clock Speed
2.7 GHz
Max Turbo Speed
3.2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1155 Socket
Chipset Type
Intel H61 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Channel Qty
3
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
9 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DVI
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
Stereo
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Preferred Pro USB
USB
Mouse
Optical
USB
Integrated
Ethernet Controller
Realtek RTL8111E
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x internal 3.5" x 1/3H , 1 (total) / 0 (free) x external 1.5"
Slots
2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile
6 x USB 2.0 (2 front, 4 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-D , 1 x audio line-in , 1 x audio line-out , 1 x serial , 1 x parallel
Administrator password, hard drive password, power-on password, boot without keyboard or mouse, USB port control, boot sequence control
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
RoHS
TopSeller
Power supply
Power Provided
180 Watt
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
33.6 cm
38.2 cm
10.1 cm
6 kg
