The new ThinkCentre Tiny Under Desk Mount Bracket can be easily installed
under your desk to enable more desktop and floor space while providing a secure solution to protect your Tiny PC. This attractive space-saving solution is constructed of high-grade steel and mounts easily with four screws. The open architecture provides easy access to media drives and control buttons of your ThinkCentre Tiny PC.
- Lenovo Tiny Under Desk Mount Bracket - system mounting bracket
- Product Type
- System mounting bracket
- Product Material
- Steel
- 19.9 cm x 10.5 cm x 22.89 cm
- 760 g
- 3-year warranty
- Designed For
- ThinkCentre M625q; M700; M70q; M70q Gen 2; M70q Gen 3; M715q; M75q Gen 2; M75q-1; M75t Gen 2; M80q; M80q Gen 3; M900; M900x; M90q; M90q Gen 2; M90q Gen 3; M910q; M920q; M93p; ThinkStation P330; P340; P350; P360
- Product Type
- Product Material
- Steel
- 19.9 cm
- 10.5 cm
- 22.89 cm
- 760 g
- Limited warranty: replacement - 3 years
- Designed For
- Lenovo ThinkCentre M625q 10TG, 10TJ (tiny), 10TK , Lenovo ThinkCentre M700 , Lenovo ThinkCentre M70q 11DT, 11DU (tiny), 11DV, 11DW, 11E7, 11E8 , Lenovo ThinkCentre M70q Gen 2 11N0, 11N3 , Lenovo ThinkCentre M70q Gen 3 11T3, 11T4 , Lenovo ThinkCentre M715q (tiny), 10M2 (tiny), 10M3 (tiny) , Lenovo ThinkCentre M75q Gen 2 11JJ, 11JK, 11JL, 11JM, 11JN, 11JQ, 11JS , Lenovo ThinkCentre M75q-1 11A4, 11A5, 11A7 , Lenovo ThinkCentre M75t Gen 2 11W5 , Lenovo ThinkCentre M80q 11DN, 11DQ, 11DS (tiny), 11EG , Lenovo ThinkCentre M80q Gen 3 11U1, 11U3 , Lenovo ThinkCentre M900 10FL, 10FM, 10FR (tiny), 10FS (tiny), 10NE , Lenovo ThinkCentre M900x , Lenovo ThinkCentre M90q 11CR (tiny), 11DG (tiny), 11DH, 11DJ, 11DK, 11DL, 11F0 , Lenovo ThinkCentre M90q Gen 2 11MQ, 11MR, 11MU, 11MV , Lenovo ThinkCentre M90q Gen 3 11U5, 11U8 , Lenovo ThinkCentre M910q , Lenovo ThinkCentre M920q 10RR, 10RS, 10RT, 10RU, 10SY, 10T1 , Lenovo ThinkCentre M93p , Lenovo ThinkStation P330 30CF, 30CG , Lenovo ThinkStation P340 30DE (tiny), 30DG, 30DR, 30DU , Lenovo ThinkStation P350 30EF, 30EG, 30EJ , Lenovo ThinkStation P360 30FA
