Lenovo ThinkCenter Tiny Under Desk Mount
Quicklinx: B3VNWS00 Mfr#: 0b47097
The new ThinkCentre Tiny Under Desk Mount Bracket can be easily installed
under your desk to enable more desktop and floor space while providing a secure solution to protect your Tiny PC. This attractive space-saving solution is constructed of high-grade steel and mounts easily with four screws. The open architecture provides easy access to media drives and control buttons of your ThinkCentre Tiny PC.
Lenovo Tiny Under Desk Mount Bracket - system mounting bracket
System mounting bracket
Product Material
Steel
19.9 cm x 10.5 cm x 22.89 cm
760 g
3-year warranty
ThinkCentre M625q; M700; M70q; M70q Gen 2; M70q Gen 3; M715q; M75q Gen 2; M75q-1; M75t Gen 2; M80q; M80q Gen 3; M900; M900x; M90q; M90q Gen 2; M90q Gen 3; M910q; M920q; M93p; ThinkStation P330; P340; P350; P360
Product Material
Steel
19.9 cm
10.5 cm
22.89 cm
760 g
Limited warranty: replacement - 3 years
Lenovo ThinkCentre M625q 10TG, 10TJ (tiny), 10TK , Lenovo ThinkCentre M700 , Lenovo ThinkCentre M70q 11DT, 11DU (tiny), 11DV, 11DW, 11E7, 11E8 , Lenovo ThinkCentre M70q Gen 2 11N0, 11N3 , Lenovo ThinkCentre M70q Gen 3 11T3, 11T4 , Lenovo ThinkCentre M715q (tiny), 10M2 (tiny), 10M3 (tiny) , Lenovo ThinkCentre M75q Gen 2 11JJ, 11JK, 11JL, 11JM, 11JN, 11JQ, 11JS , Lenovo ThinkCentre M75q-1 11A4, 11A5, 11A7 , Lenovo ThinkCentre M75t Gen 2 11W5 , Lenovo ThinkCentre M80q 11DN, 11DQ, 11DS (tiny), 11EG , Lenovo ThinkCentre M80q Gen 3 11U1, 11U3 , Lenovo ThinkCentre M900 10FL, 10FM, 10FR (tiny), 10FS (tiny), 10NE , Lenovo ThinkCentre M900x , Lenovo ThinkCentre M90q 11CR (tiny), 11DG (tiny), 11DH, 11DJ, 11DK, 11DL, 11F0 , Lenovo ThinkCentre M90q Gen 2 11MQ, 11MR, 11MU, 11MV , Lenovo ThinkCentre M90q Gen 3 11U5, 11U8 , Lenovo ThinkCentre M910q , Lenovo ThinkCentre M920q 10RR, 10RS, 10RT, 10RU, 10SY, 10T1 , Lenovo ThinkCentre M93p , Lenovo ThinkStation P330 30CF, 30CG , Lenovo ThinkStation P340 30DE (tiny), 30DG, 30DR, 30DU , Lenovo ThinkStation P350 30EF, 30EG, 30EJ , Lenovo ThinkStation P360 30FA
