Lenovo ThinkCenter Tiny Under Desk Mount
Quicklinx: B3VNWS00 Mfr#: 0b47097
Accessory Type: Mount
More than 50 in stock
£34.29 ex VAT
£41.14 inc VAT
The new ThinkCentre Tiny Under Desk Mount Bracket can be easily installed
under your desk to enable more desktop and floor space while providing a secure solution to protect your Tiny PC. This attractive space-saving solution is constructed of high-grade steel and mounts easily with four screws. The open architecture provides easy access to media drives and control buttons of your ThinkCentre Tiny PC.
Lenovo Tiny Under Desk Mount Bracket system mounting bracket
System mounting bracket
Product Material
Steel
19.9 cm x 10.5 cm x 22.89 cm
760 g
3-year warranty
ThinkCentre M625q; M700; M70q; M715q; M75q Gen 2; M75q-1; M80q; M900; M900x; M90q; M910q; M920q; M93p; ThinkStation P330; P340
Product Material
Steel
19.9 cm
10.5 cm
22.89 cm
760 g
Limited warranty - replacement - 3 years
Lenovo ThinkCentre M625q 10TG, 10TJ (tiny), 10TK , Lenovo ThinkCentre M700 , Lenovo ThinkCentre M70q 11DT, 11DU (tiny), 11DV, 11DW , Lenovo ThinkCentre M715q (tiny), 10M2 (tiny), 10M3 (tiny) , Lenovo ThinkCentre M75q Gen 2 11JJ, 11JK, 11JL, 11JM , Lenovo ThinkCentre M75q-1 11A4, 11A5, 11A7 , Lenovo ThinkCentre M80q 11DN, 11DQ, 11DS (tiny), 11EG , Lenovo ThinkCentre M900 10FL, 10FM, 10FR (tiny), 10FS (tiny), 10NE , Lenovo ThinkCentre M900x , Lenovo ThinkCentre M90q 11CR (tiny), 11DG (tiny), 11DH, 11DJ, 11DL, 11F0 , Lenovo ThinkCentre M910q , Lenovo ThinkCentre M920q 10RR, 10RS, 10RT, 10RU, 10SY, 10T1 , Lenovo ThinkCentre M93p , Lenovo ThinkStation P330 30CF, 30CG , Lenovo ThinkStation P340 30DE (tiny), 30DG, 30DR
Brand: Lenovo
Stock Status: In stock
