A tablet for the whole family
Whether it’s for homework, online shopping, or a screen-time treat, the Tab 4 8 is ideal for the whole family. Stylish yet rugged, this smooth-performing tablet has a vibrant 8" display, enhanced audio, and long battery life. Everyone can have their own account and there are optional add-ons aimed specifically for the younger ones.
High-end design
The Tab M8 (2 nd Gen) was made for users who appreciate good style and design. Only 8.15mm thin, with a metal back cover and rounded edges, this tablet feels great in your hands and exudes elegance. -
Check out the view
Gone are the days of tablets with tinny sound and grainy video. The Tab M8 (2 nd Gen) brings an IPS HD touchscreen display that uses 82% of the tablet's surface area for seamless visuals, and a Dolby Audio-tuned speaker. This one-two punch of visual and audio pleasure makes streaming your favorite videos and playing mobile games even more enjoyable. -
Everything you need
With Android 9 Pie, a quad-core processor, and a battery that provides up to 18 hours of web browsing, the Tab M8 (2 nd Gen) is your key to nonstop entertainment. Watch videos, check social media, listen to music, and so much more-this tablet delivers. -
Stare all you want
The Tab M8 (2 nd Gen)'s TÜV-certified display cuts back blue light that's potentially damaging to eyesight, especially for growing children. So, you and your family can watch and play for hours on long trips and slow days at home with peace of mind.
- Lenovo Tab M8 HD (2nd Gen) ZA5G - tablet - Android 9.0 (Pie) - 32 GB - 8"
- Product Type
- Tablet
- Operating System
- Android 9.0 (Pie)
- Display
- 8" IPS TFT - LED backlight - 1280 x 800 - Multi-Touch
- Processor
- MediaTek Helio A22 (Quad-Core) - 64-bit
- Processor Clock Speed
- 2 GHz
- Storage
- 32 GB Embedded Multi-Chip Package
- RAM
- 2 GB
- Supported Flash Memory Cards
- microSD
- Wireless Connectivity
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Rear Camera
- 5 Megapixel
- Front Camera
- 2 Megapixel
- Radio Tuner Type
- FM radio
- Battery Run Time
- Up to 18 hours
- 19.91 cm x 0.815 cm x 12.18 cm
- 305 g
- Iron grey
- Localisation
- United Kingdom
- 1-year warranty
- Product Type
- Tablet
- Operating System
- Android 9.0 (Pie)
Display
- Resolution
- 1280 x 800
- Colour Gamut
- 60%
- Touchscreen
- Multi-Touch
- Image Brightness
- 350 cd/m²
- 10-point multi-touch, capacitive touch screen, 160° viewing angle
- Processor
- 2 GHz
- Number of Cores
- Quad-Core
- 64-bit Computing
- Storage
- RAM
- 2 GB - LPDDR3 SDRAM
- microSD
- Max Supported Capacity
- 128 GB
Communications
- Wi-Fi Direct
Rear Camera
- Sensor Resolution
- 5 Megapixel
Front Camera
- Sensor Resolution
- 2 Megapixel
Multimedia
- Graphics
- IMG GE8300
- Supported Digital Audio Standards
- Dolby Atmos
- Radio Tuner Type
- FM radio
- Audio
- Microphone, speaker
Software
- Preloaded Software
- Camera, Files, Gmail, YouTube, Google Calendar, Netflix, FM Radio, Google Chrome, Google Maps, Google Photo, Google Duo
Expansion and Connectivity
- Expansion Slots
- 1 x microSD
- 1 x Micro-USB , 1 x headset mini jack (3.5mm)
- Technology
- Lithium Ion
- Capacity
- 5100 mAh
- Run Time
- Up to 18 hours
- Standby Time
- 336 h
- Run Time Details
- Video playback over Wi-Fi: up to 12 hour(s) , Web browsing: up to 18 hour(s)
- Recharge Time
- 3.3 hour(s)
- Iron grey
- Case Material
- Plastic, metal
- Sensors
- Accelerometer, ambient light sensor, proximity sensor
- Vibrating Alert
- Included Accessories
- Power adapter
- RoHS, IP5X
- Localisation
- United Kingdom
- 19.91 cm
- 0.815 cm
- 12.18 cm
- 305 g
- Limited warranty - 1 year - pick-up and return
