Households in which tablets see the heaviest multimedia use can opt for the ultra-premium Lenovo Tab P10. Lenovo's flagship Android tablet redefines the family tablet with a head-turning dual-glass design, all-metal framing and narrow bezels in an ultra-slim and light profile, while its stunning casing gives off a stunning aurora reflection design as you turn it.
But it's in the entertainment features where the Lenovo Tab P10 truly shines, with four (yes, four) speakers that will make the best use of Dolby Atmos. The Lenovo Tab P10 is equipped with an auto-focus rear camera and fixed focus front camera.
A tablet this stunning and powerful will definitely see a lot of use, featuring an ultra-fast fingerprint sensor that takes full advantage of the built-in multi-user capabilities. Once a family member profile is created, simply tap your finger on the fingerprint sensor to log into your own personalized tablet experience, which houses your wallpapers, settings, apps, games and personal files, all kept separately from the experiences of your parents, siblings or kids in the home.
Handcrafted to perfection
You've never seen a tablet look quite this good before. Tab P10 features a standout dual-glass design, all metal framing, and narrow bezels. Put simply, it's beautiful to look at and a pleasure to hold. -
You won't want to look away
Treat your eyes to something truly special. The Tab P10's 10.1" FHD display captures everything from the intensity of an action scene to the beautiful details in family photos. -
Enhanced 4-speaker sound
Immerse yourself in deep, booming sound that delivers a theater-like experience for movies, shows, and videos. Its four front speakers and Dolby Atmos support deliver an immersive, cinematic experience. -
The ultimate family tablet
Every member of the family will have their own tailored-and secure-experience with the Tab P10. Each user gets their own account-accessible through a multi-user fingerprint reader-with individualized settings, wallpaper, and social media accounts. -
Kid mode keeps little ones safe
Since every member of the family gets their own account on the Tab P10, parents can make sure their kids stay safe. Secure the content your kids access and put time limits on their usage. The Tab P10 also boasts enhanced eye protection and easy-to-use voice search.
- Lenovo Tab P10 ZA44 - tablet - Android 9.0 (Pie) - 32 GB - 10.1"
- Product Type
- Tablet
- Operating System
- Android 9.0 (Pie)
- Display
- 10.1" IPS TFT - LED backlight - 1920 x 1200 - Multi-Touch
- Processor
- Qualcomm Snapdragon 450 (8-core) - 64-bit
- Processor Clock Speed
- 1.8 GHz
- Storage
- 32 GB Embedded Multi-Chip Package
- RAM
- 3 GB
- Supported Flash Memory Cards
- microSD
- Wireless Connectivity
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Rear Camera
- 8 Megapixel
- Front Camera
- 5 Megapixel
- Navigation System
- A-GPS/GPS/GLONASS
- Radio Tuner Type
- FM radio
- Security Devices
- Fingerprint reader
- Battery Run Time
- Up to 12 hours
- 16.7 cm x 0.7 cm x 24.2 cm
- 440 g
- Aurora black
- Localisation
- United Kingdom
- Manufacturer Selling Program
- TopSeller
- 1-year warranty
- Product Type
- Tablet
- Operating System
- Android 9.0 (Pie)
Display
- Resolution
- 1920 x 1200
- Colour Gamut
- 70%
- Touchscreen
- Multi-Touch
- Image Brightness
- 400 cd/m²
- 10-point multi-touch
- Processor
- 1.8 GHz
- Number of Cores
- 8-core
- 64-bit Computing
- Storage
- RAM
- 3 GB - LPDDR3 SDRAM
- microSD
- Max Supported Capacity
- 256 GB
Communications
- Wi-Fi Direct
Rear Camera
- Sensor Resolution
- 8 Megapixel
Front Camera
- Sensor Resolution
- 5 Megapixel
Navigation System
- Receiver
- A-GPS/GPS/GLONASS
Multimedia
- Graphics
- Qualcomm ADRENO 506
- Supported Digital Audio Standards
- Dolby Atmos
- Radio Tuner Type
- FM radio
- Audio
- Microphone, four speakers
Input Device
- Security Devices
Software
- Preloaded Software
- Clock, Calculator, Contacts, File Manager, Recorder, Launcher, Camera, Skype, Gmail, Google Music, Google Calendar, Netflix, Weather, FM Radio, Google Plus Messenger, Google Chrome, Google Docs, Settings, Microsoft Outlook, Notification Center, Google Photo, Google Sheets, ePOS, Out-of-box experience (OOBE), Google Files Go, Google Slides
Expansion and Connectivity
- Expansion Slots
- 1 x microSD
- 1 x USB-C/USB 2.0 , 1 x headset mini jack (3.5mm) , 2 x POGO pin
- Technology
- Lithium Ion
- Capacity
- 7000 mAh
- Run Time
- Up to 12 hours
- Standby Time
- 336 h
- Run Time Details
- Video playback: up to 12 hour(s) , Web browsing: up to 12 hour(s)
- Aurora black
- Case Material
- Aluminum, glass
- Sensors
- Accelerometer, ambient light sensor, hall sensor
- Vibrating Alert
- Included Accessories
- Power adapter
- RoHS
- Localisation
- United Kingdom
- TopSeller
- 16.7 cm
- 0.7 cm
- 24.2 cm
- 440 g
- Limited warranty - 1 year
