The ThinkPad USB 3.0 Ethernet adapter enables Ethernet on systems which do not have Ethernet RJ-45 connector through USB port on the system. The ThinkPad USB 3.0 Ethernet adapter not only provides high-speed Gigabit Ethernet solution via USB 3.0 port but also enables boot over the LAN on selected ThinkPad systems.
Connect it with your Ultrabook or Tablet to your corporate VPN at the office or go online in your hotel while you're travelling. The adapter's small form factor allows a convenient fit into any computer case or travel bag, so you can easily take it with you anywhere.
- Lenovo ThinkPad - network adapter - USB 3.0 - Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- Gigabit Ethernet
- 5 cm 3 cm
- Length
- 18 cm
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3az
- System Requirements
- Microsoft Windows 7 (32/64 bits), Windows 8 64-bit Edition, Windows 8.1
- 1-year warranty
- Network adapter
- Form Factor
- External
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- PoE, QoS
- 1 x 1000Base-T - RJ-45 - female
- VCCI, C-Tick, BSMI, CB, FCC, ACA, ICES, KC, EAC
- OS Required
- 5 cm
- 3 cm
- Length
- 18 cm
- Limited warranty - 1 year
- 0 °C
- 70 °C
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
