Product
Lenovo SuperSpeed USB 3.0 to Ethernet Adapter
Quicklinx: 9FYGWS00 Mfr#: 4X90E51405
The ThinkPad USB 3.0 Ethernet adapter enables Ethernet on systems which do not have Ethernet RJ-45 connector through USB port on the system. The ThinkPad USB 3.0 Ethernet adapter not only provides high-speed Gigabit Ethernet solution via USB 3.0 port but also enables boot over the LAN on selected ThinkPad systems.
Connect it with your Ultrabook or Tablet to your corporate VPN at the office or go online in your hotel while you're travelling. The adapter's small form factor allows a convenient fit into any computer case or travel bag, so you can easily take it with you anywhere.
Lenovo ThinkPad - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
5 cm 3 cm
Length
18 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3az
Microsoft Windows 7 (32/64 bits), Windows 8 64-bit Edition, Windows 8.1
1 year warranty
Miix 320-10; 510-12; 520-12; 710-12; Tablet 10; ThinkCentre M700; M710; M910; ThinkPad A275; A285; A475; A485; E475; E48X; E57X; E58X; L380; L380 Yoga; L470; L480; L570; L580; P1; P51; P52; P71; P72; T25; T470; T480; T570; T580; X380 Yoga; ThinkPad Yoga 370; V110-14; V110-17; V310-14
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Power over Ethernet (PoE), Quality of Service (QoS)
1 x 1000Base-T - RJ-45 - female
VCCI, C-Tick, BSMI, CB, FCC, ACA, ICES, KC, EAC
5 cm
3 cm
Length
18 cm
Limited warranty - 1 year
70 °C
Lenovo Miix 320-10ICR , Lenovo Miix 510-12IKB , Lenovo Miix 510-12ISK , Lenovo Miix 520-12IKB , Lenovo Miix 710-12IKB , Lenovo S500 , Lenovo Tablet 10 , Lenovo ThinkCentre Chromebox , Lenovo ThinkCentre M600 , Lenovo ThinkCentre M700 10JM, 10JT , Lenovo ThinkCentre M700z , Lenovo ThinkCentre M710q , Lenovo ThinkCentre M710s , Lenovo ThinkCentre M710t , Lenovo ThinkCentre M800z , Lenovo ThinkCentre M900 , Lenovo ThinkCentre M900z , Lenovo ThinkCentre M910q , Lenovo ThinkCentre M910x , Lenovo Thinkpad 13 , Lenovo Thinkpad 13 Chromebook , Lenovo ThinkPad A275 20KC, 20KD , Lenovo ThinkPad A285 , Lenovo ThinkPad A475 20KL, 20KM , Lenovo ThinkPad A485 , Lenovo ThinkPad E455 , Lenovo ThinkPad E460 , Lenovo ThinkPad E465 , Lenovo ThinkPad E475 , Lenovo ThinkPad E480 , Lenovo ThinkPad E485 , Lenovo ThinkPad E560 , Lenovo ThinkPad E565 , Lenovo ThinkPad E570 , Lenovo ThinkPad E575 , Lenovo ThinkPad E580 , Lenovo ThinkPad E585 , Lenovo ThinkPad Edge L330 , Lenovo ThinkPad L380 , Lenovo ThinkPad L380 Yoga , Lenovo ThinkPad L460 , Lenovo ThinkPad L470 , Lenovo ThinkPad L480 , Lenovo ThinkPad L560 , Lenovo ThinkPad L570 , Lenovo ThinkPad L580 , Lenovo ThinkPad P1 , Lenovo ThinkPad P40 Yoga , Lenovo ThinkPad P50 , Lenovo ThinkPad P50s , Lenovo ThinkPad P51s , Lenovo ThinkPad P52 , Lenovo ThinkPad P70 , Lenovo ThinkPad P71 , Lenovo ThinkPad P72 , Lenovo ThinkPad T25 , Lenovo ThinkPad T460 , Lenovo ThinkPad T460p , Lenovo ThinkPad T460s , Lenovo ThinkPad T470p , Lenovo ThinkPad T480 , Lenovo ThinkPad T480s , Lenovo ThinkPad T560 , Lenovo ThinkPad T570 , Lenovo ThinkPad T580 , Lenovo ThinkPad W541 , Lenovo ThinkPad W550s , Lenovo ThinkPad X1 Tablet , Lenovo ThinkPad X1 Yoga , Lenovo ThinkPad X131e Chromebook , Lenovo ThinkPad X260 , Lenovo ThinkPad X380 Yoga , Lenovo ThinkPad Yoga 260 , Lenovo ThinkPad Yoga 370 , Lenovo ThinkPad Yoga 460 , Lenovo V110-14IAP , Lenovo V110-17ISK , Lenovo V310-14IKB , Lenovo V310-14ISK
9FYG C2G 2m USB 2.0 A/B Cable - Black In Stock £3.10
9FYG C2G 5m USB 2.0 A/B Cable - Black In Stock £4.54
9FYG C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.63
9FYG C2G 4-Port USB 2.0 Aluminum Hub In Stock £19.32
9FYG C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.57
9FYG C2G USB 2.0 To Fast Ethernet Adapter In Stock £21.06
9FYG C2G USB Superbooster Extender Kit In Stock £37.45
9FYG C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.15
9FYG C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
