The s510 SFF packs high performance into a small footprint, low cost machine. Advanced wireless with enhanced antenna design, plenty of memory and storage, and a sleek, modern design make this a perfect solution for home or small business.
Intel Core i processor
The Intel Core i processor delivers 11% faster performance than the previous generation processor, you'll experience extraordinary productivity. -
Big power in a small form-factor
The S510 has been put through over 200 reliability tests including shock, drop and vibrations tests in order to maximize both the life of the system and your ROI. -
Enhanced security
An array of security features such as Smart USB Protection, which restricts port access while allowing keyboard and mouse inputs, will provide you with peace of mind. -
Green and sustainable
The S510 has earned the green certifications of Energy Star 6.1, GREENGUARD, WEEE, and more. Green certification means decreased power consumption, which translates to lower power costs for your small business.
- Lenovo S510 - SFF - Core i5 6400 2.7 GHz - 4 GB - SSD 128 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- Intel Core i5 (6th Gen) 6400 / 2.7 GHz (, up to 3.3 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 128 GB - SATA 6Gb/s
- Optical Storage
- DVD SuperMulti
- Card Reader
- 10 in 1
- Graphics Controller
- Intel HD Graphics 530
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Black
- 29.5 cm x 32 cm x 9 cm
- 4.13 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.7 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- SSD
- Capacity
- 1 x 128 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 3
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Card Reader
- 10 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111GN
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 0 (free) x external
- Slots
- 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
- 4 x USB 3.0 (2 front, 2 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 2 x USB 2.0 (2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x audio line-in , 1 x audio line-out
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- Efficiency
- 85%
Operating System / Software
- OS Provided
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 29.5 cm
- 32 cm
- 9 cm
- 4.13 kg
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable | In Stock | £32.58 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.82 |
