This versatile S500 desktop has an extra small form factor and footprint. Though compact, it delivers amazing performance. An extensive range of ports delivers seamless connectivity while the USB protection technology and Lenovo Bluetooth Lock secure your data.
Compact for versatility
Total versatility results from a smaller footprint and a convenient form factor. -
Excellent security
Lenovo USB protection technology allows you to restrict port access while allowing keyboard and mouse inputs. Lenovo Bluetooth Lock means your desktop will automatically lock once you step away. -
Maximum productivity
A range of ports ensures connectivity with all the peripherals you need.
- Lenovo S500 - SFF - Core i3 4170 3.7 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- Intel Core i3 (4th Gen) 4170 / 3.7 GHz (Dual-Core)
- Processor Socket
- LGA1150 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Smart Cache
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD
- Card Reader
- Graphics Controller
- Intel HD Graphics 4400
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- 9 cm x 32 cm x 29.5 cm
- 4.13 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel H81
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total)
- Unbuffered
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 2
Optical Storage
- DVD-ROM DVD
Card Reader
- Card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 1 (total) / 0 (free) x external 5.25" x 1/6H (Slim Line) , 1 (total) / 0 (free) x internal 3.5"
- Slots
- 2 DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 M.2 Card , 1 (total) / 1 (free) x PCIe x16 - low-profile
- 2 x USB 3.0 , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 4 x USB 2.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x audio line-in , 1 x audio line-out
- Theft/Intrusion Protection
- RoHS, WEEE
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- 80 PLUS Certification
- 80 PLUS
- Efficiency
- 85%
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 9 cm
- 32 cm
- 29.5 cm
- 4.13 kg
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
