The redesigned Lenovo Preferred Pro Fingerprint USB Keyboard offers users the convenience to gain access to confidential files with the swipe of a finger. The state of the art biometric solution for authentication gives you the convenience of simple fingerprint authentication only, or configure for one of the most secure log-in processes available.
- Lenovo Preferred Pro USB Fingerprint - keyboard - UK
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Security Devices
- Fingerprint reader
- Non-slip feet, height-adjustable feet, NumLock function
- 45.32 cm x 18.17 cm x 2.19 cm
- 920 g
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Keyboard
- Interface
- USB
Input Device
- UK
- Security Devices
- 45.32 cm
- 18.17 cm
- 2.19 cm
- 920 g
- Cables Included
- 1 x USB cable - 2.5 m
- UL, TUV, VCCI, C-Tick, BSMI, FCC, KC, EAC
- Included Software
- ThinkVantage Client Security Software, Fingerprint Software
- OS Required
- Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
- Limited warranty - 3 years
- 0 °C
- 50 °C
- 20 - 80%
