The ThinkStation P510 is a workstation that's powerful enough for any job and reliable enough for mission-critical environments. It's scalable, flexible, and gives you the power, performance and usability you need.
- Lenovo ThinkStation P510 - tower - Xeon E5-1650V4 3.6 GHz - 8 GB - SSD 256 GB - UK
- Workstation - tower
- Localisation
- Processor
- 1 x Intel Xeon E5-1650V4 / 3.6 GHz (, up to 4 GHz, (6-core)
- Processor Socket
- LGA2011-v3 Socket
- Cache Memory
- 15 MB
- Cache Per Processor
- 15 MB
- RAM
- 8 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-19200
- Storage Controller
- RAID (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s - TCG Opal Encryption
- Optical Storage
- DVD-Writer
- Card Reader
- 9 in 1
- Graphics Controller
- NVIDIA Quadro M2000
- Video Memory
- 4 GB
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 17.5 cm x 47 cm x 44 cm
- 22.2 kg
- Manufacturer Selling Program
- TopSeller
- Limited warranty - 3 years - on-site - response time: next business day
- Workstation
- Product Form Factor
- Tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-1650V4
- Clock Speed
- 3.6 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 15 MB
- 15 MB
RAM
- Installed Size
- 8 GB / 256 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- DIMM 288-pin
- Slots
- 8 (Total) / 7 (empty)
- Registered
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD-Writer
Card Reader
- 9 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Memory
- 4 GB
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 4
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Scroll
- Ethernet Controller
- Intel I218-LM
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 2 (total) / 1 (free) x external 5.25" x 1/2H , 4 (total) / 3 (free) x internal 3.5"
- Slots
- 8 (total) / 7 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x4 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x1 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height
- 8 x USB 3.0 (4 front, 4 rear) (one of them is Always On, one of them is Diagnostic) , 1 x headphones/microphone (1 in front) , 1 x microphone , 4 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse , 4 x DisplayPort
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS, GREENGUARD
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 490 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Efficiency
- 90%
Operating System / Software
- OS Provided
- 17.5 cm
- 47 cm
- 44 cm
- 22.2 kg
- 10 °C
- 35 °C
- 10 - 80% (non-condensing)
