Lenovo N23 Winbook Intel Celeron N3160 4GB 128GB SSD 11.6" Windows 10 Home
Quicklinx: D17WWS00 Mfr#: 80UR0052UK
  • Celeron
  • IEEE 802.11n
Powerful enough for the classroom. Rugged enough for the road
The Lenovo N23 is powered by the 6th Gen Intel Braswell processor giving you the performance of a desktop with the mobility of a laptop. The yoga-type design allows you to use it in 4 different modes depending on your activity: Laptop, Tablet, Tent and Stand. The rugged engineering means that dust and spills are not going to be a problem. With up to 8 hours of battery life it is perfect for hard workers.
Key Features
  • Vibrant 11.6" HD IPS Touchscreen Incredible sharpness meets the versatility of a touchscreen in the Lenovo N23. The 11.6" screen hits the sweet spot between comfortable viewing and portability.
  • Rugged IPS52 - Certified design
    Dust-proof and spill proof, the precision crafted design allows the N23 to withstand everything from classrooms to the great outdoors.
  • Versatile Yoga Design The flexible hinge allows you to use the N23 in 4 modes: Laptop, tablet, tent, and stand. This versatile form factor makes it a joy to work, work videos, or use it as a tablet.
  • Long battery life
    From classroom to study group, the N23 offer enough juice for all-day productivity.
Lenovo N23 80UR - 11.6" - Celeron N3060 - 4 GB RAM - 128 GB SSD
Notebook
Operating System
Win 10 Home 64-bit
Intel Celeron N3060 / 1.6 GHz (2.48 GHz) / 2 MB Cache
4 GB DDR3L
Storage
128 GB - M.2 SSD
Optical Drive
No optical drive
Display
11.6" LED backlight touchscreen 1366 x 768 / HD
Graphics
Intel HD Graphics 400
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac
3-cell
30.05 cm x 21.25 cm x 2.33 cm
1.4 kg
English / United Kingdom
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
2.48 GHz
Number of Cores
Dual-Core
Cache
L2 - 2 MB
64-bit Computing
Integrated memory controller, Intel Burst Technology
RAM
4 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz
Storage
Main Storage
128 GB SSD - (M.2)
Display
11.6"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Resolution
1 Megapixel
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7260 - M.2 Card
3-cell Lithium Ion
45 Wh
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
2 x USB 2.0 , USB 3.0 , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Mini security lock slot (cable lock sold separately)
Power adapter
Localization
1.4 kg
