Powerful enough for the classroom. Rugged enough for the road
The Lenovo N23 is powered by the 6th Gen Intel Braswell processor giving you the performance of a desktop with the mobility of a laptop. The yoga-type design allows you to use it in 4 different modes depending on your activity: Laptop, Tablet, Tent and Stand. The rugged engineering means that dust and spills are not going to be a problem. With up to 8 hours of battery life it is perfect for hard workers.
Key Features
- Vibrant 11.6" HD IPS Touchscreen Incredible sharpness meets the versatility of a touchscreen in the Lenovo N23. The 11.6" screen hits the sweet spot between comfortable viewing and portability.
- Rugged IPS52 - Certified design. Dust-proof and spill proof, the precision crafted design allows the N23 to withstand everything from classrooms to the great outdoors.
- Versatile Yoga Design The flexible hinge allows you to use the N23 in 4 modes: Laptop, tablet, tent, and stand. This versatile form factor makes it a joy to work, work videos, or use it as a tablet.
- Long battery life. From classroom to study group, the N23 offer enough juice for all-day productivity.
- Lenovo N23 - 11.6" - Intel Celeron - N3060 - 4 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Celeron N3060 / 1.6 GHz, up to 2.48 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 128 GB SSD
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics 400
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac
- Battery
- 3-cell
- 30.05 cm x 21.25 cm x 2.33 cm
- 1.4 kg
- Localisation
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.48 GHz
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- Integrated memory controller, Intel Burst Technology
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 128 GB SSD M.2
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Resolution
- 1 Megapixel
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7260 - M.2 Card
- Technology
- 3-cell Lithium Ion
- Capacity
- 45 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- 2 x USB 2.0 , USB 3.0 , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington mini security slot
- Included Accessories
- Power adapter
- Localization
- 1.4 kg
Sustainability Information
- TCO Certified
