. Experience immersive virtual reality without a separate PC or smartphone. Deploy Google's powerful WorldSense technology to lean, dodge, duck, move, avoid obstacles, and move naturally through an ever-growing library of virtual worlds. The future of VR has arrived.
Standalone, no strings attached
The first to offer true, unfettered freedom through standalone virtual reality, Mirage Solo delivers the same immersive capabilities as PC-powered virtual reality experiences, with none of the baggage. Slide the headset on, and get ready to experience the virtual world. No wires, no extra sensors, no extra cost or complexity. -
Move naturally
Lean and duck to navigate your way through tight spaces; jump to traverse pitfalls and dodge to avoid incoming projectiles. Objects and landscapes stay fixed in place no matter where you tilt or move your head. -
Discover a whole new way to daydream
With Mirage Solo, not only do you have access to over 250 Daydream apps, you'll unlock the potential of apps powered by WorldSense tracking. From gaming to VR travel to live events, there are now countless worlds to explore. -
Designed to disappear
A device shouldn't get in the way of experiencing virtual reality. The Mirage Solo was ergonomically designed so you can comfortably stay immersed in that virtual world for long periods of time. The Mirage Solo is light, adjustable and fine-tuned for comfort and balanced load distribution - eliminating friction and strain against the bridge of your nose. The headset is precisely adjustable, so you can find the perfect fit. -
Broaden your horizons, and your sight lines
The Mirage Solo increases the angle of your line of sight with a 110-degree field of view, one of the widest in its category. Now, you can see more than ever on the headset's ultrahigh-resolution display, which features Lenovo advanced display technology, a revolutionary, VR-optimized LCD display that renders exceptional clarity designed exclusively for Daydream. -
A powerful engine, built for seamless, free-roam virtual reality
The Mirage Solo equips you to get the most out of Daydream's virtual reality experiences. The headset is powered by the advanced Qualcomm Snapdragon 835 VR platform and 4 GB of RAM. This powerful engine pushes your experience to its full potential, whether you're dodging enemy attacks in effortless real time or wandering through an ancient forest temple steeped in lore and mystery.
- Lenovo Mirage Solo - virtual reality system - 5.5"
- Virtual reality system - 5.5"
- microSD card reader, 2 x 6 DOF cameras
- Sensors
- Accelerometer, proximity sensor, magnetometer, gyro sensor
- Native Resolution
- QHD 2560 x 1440 at 75 Hz
- Resolution per Eye
- 5.5" - 2560 x 1440
- Field of View
- 110°
- Colour Support
- 16.7 million colours
- Colour Gamut
- 70%
- Input Connectors
- 802.11ac
- Battery Run Time
- Up to 2.5 hours
- Moonlight white
- Dimensions (WxDxH) - headset
- 20.4 cm x 26.95 cm x 17.986 cm
- 645 g
- 1-year warranty
- Display Type
- Diagonal Size
- 5.5"
- Built-in Devices
- Native Resolution
- Colour Support
- Colour Gamut
- 70%
- Moonlight white
- 20.4 cm x 26.95 cm x 17.986 cm - headset
- 645 g
VR Headset
- 2560 x 1440
- Diagonal Size per Eye
- 5.5"
- Field of View
- 110°
- Sensors
- Control Type
- Bluetooth motion controller
- Adjustable headband, volume keys, Fresnel lenses, 6DoF Tracking Architecture
- Headphones
- Bluetooth interface
- Included Accessories
- Wireless Daydream motion controller, 3.5 mm VR optimised earphones
- Cables Included
- 1 x USB-C cable
- Technology
- Lithium polymer
- Capacity
- 4000 mAh
- Run Time (Up To)
- 2.5 hours
- Included Software
- YouTube, Google Street View, Lenovo Out Of Box Experience (OOBE), ePOS, Google Arts and Culture, Google Photos
- Limited warranty - 1 year
