Lenovo Mini Display Port to VGA Adapter
Quicklinx: 8RVVWS00 Mfr#: 0A36536
Length: 20cm
11 in stock
£32.79 ex VAT
£39.34 inc VAT
Standard delivery Delivered within 3-5 working days
The mini-DisplayPort interface is a miniaturized version of the popular DisplayPort digital display interface. The mini-DisplayPort to VGA adapter provides the best sleek compatibility experience as it seamlessly enables interoperability with existing analog projectors and displays. The mini-DisplayPort to VGA adapter is standards compliant with the DisplayPort standard, and also is forward compatible with Thunderbolt.
The mini-DisplayPort to VGA adapter allows you to connect to an extended display or work in mirrored mode with VGA projectors, commonly associated with VGA resolutions up to 1920 x 1200 @ 60Hz reduce blanking display resolution, so the same visual information that you see is viewed by your audience. The mini-DisplayPort to VGA adapter is color coordinated to be consistent with the superior ThinkPad experience.
Lenovo VGA cable - 20 cm
VGA cable
Length
20 cm
Connector
Mini DisplayPort - male
Connector (Second End)
HD-15 (VGA) - female
3-year warranty
Lenovo D186, L2021, LS1951, LS2221, LS2251, LS2421p; ThinkPad Helix; ThinkPad L570; P51; T430; T430i; T431s; T470p; T530; T530i; W550s; X; X1 Yoga; X240; X250; X260; ThinkVision L1711p, L1900p, L1951p, L197, L2250p, L2251p, L2251x, L2321x, L2440p, LT1952p, LT2252p, LT2452p
VGA cable
Length
20 cm
Connector
15 pin HD D-Sub (HD-15) - female
3-year warranty
Lenovo D186, L2021, LS1951, LS2221, LS2251, LS2421p , Lenovo ThinkPad L570 , Lenovo ThinkPad P51 , Lenovo ThinkPad T430 , Lenovo ThinkPad T430i , Lenovo ThinkPad T431s , Lenovo ThinkPad T470p , Lenovo ThinkPad T530 , Lenovo ThinkPad T530i , Lenovo ThinkPad W550s , Lenovo ThinkPad X1 , Lenovo ThinkPad X240 , Lenovo ThinkPad X250 , Lenovo ThinkPad X260 , Lenovo ThinkStation P330 (2nd Gen) 30D3, 30D4 , Lenovo ThinkStation P340 30DE, 30DF, 30DG, 30DH, 30DJ, 30DL, 30DM, 30DN, 30DR , Lenovo ThinkStation P520 30DC , Lenovo ThinkStation P620 30E0, 30E1 , Lenovo ThinkVision L1711p, L1900p, L1951p, L197, L2250p, L2251p, L2251x, L2321x, L2440p, LT1952p, LT2252p, LT2452p
Length: 20cm
Brand: Lenovo
Stock Status: In stock
