The Ideapad Miix 700 is an outstanding notebook with stunning performance and high-definition display. Thanks to its unique watchband hinge, the Ideapad Miix 700 will make you stand out from the crowd. As you flip effortlessly between laptop, stand, and tablet modes in your favorite coffee shop or café, be sure to check to out those envious admirers. The Ideapad Miix 700 is not just recognizably different, it also gives you great ways to work and play. A detachable Bluetooth-enabled keyboard means you can even sit apart from your Miix and still tap away. With stunning visuals and performance, the fast processor of the Ideapad Miix 700 delivers excellent processing power that allows you to work smarter.
- Lenovo IdeaPad Miix 700-12ISK - 12" - Intel Core m7 - 6Y75 - 8 GB RAM - 256 GB SSD - 4G LTE - UK
- Product Type
- Tablet - with detachable keyboard
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core m7 (6th Gen) - 6Y75 / 1.2 GHz, up to 3.1 GHz / 4 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 12" LED backlight touchscreen 2160 x 1440 / Full HD Plus
- Graphics
- Intel HD Graphics 515
- Input Device
- Keyboard, digitizer, touchpad, digital pen
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Wireless Broadband (WWAN)
- 4G LTE
- Battery
- 4-cell - up to 9 hours
- Black
- Dimensions (WxDxH) - tablet
- 29.2 cm x 21 cm x 8.95 mm
- 780 g
- Localisation
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core m7 (6th Gen) 6Y75 / 1.2 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 256 GB SSD M.2 SATA 6Gb/s
Display
- 12" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 2160 x 1440 (Full HD Plus)
- Widescreen
- Image Aspect Ratio
- 3:2
- Image Brightness
- 300 cd/m²
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 5 Megapixel (rear), 5 Megapixel (front)
- Sound
- Stereo speakers, microphone
Input
- Keyboard Layout
- UK
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Generation
- 4G
- Technology
- LTE
- Technology
- 4-cell lithium polymer
- Capacity
- 40 Wh
- Run Time
- Up to 9 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 40 Watt, 20 V, 2 A
Connections & Expansion
- Interfaces Details
- USB 2.0 , USB 3.0 , Micro-HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Black
- Hard drive password, power-on password, volume control
- Included Accessories
- Power adapter, keyboard, pen holder
- Localization
- 780 g
- Dimensions (WxDxH) / Weight Details
- 29.3 cm x 22.4 cm x 5.5 mm / 330 g - keyboard dock
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
