Lenovo Miix700 Intel Core M5 6Y54 8GB 256GB SSD 12" Win 10 Pro
Quicklinx: BXN4WS00 Mfr#: 80QL00B8UK
  • IEEE 802.11n
The Ideapad Miix 700 is an outstanding notebook with stunning performance and high-definition display. Thanks to its unique watchband hinge, the Ideapad Miix 700 will make you stand out from the crowd. As you flip effortlessly between laptop, stand, and tablet modes in your favorite coffee shop or café, be sure to check to out those envious admirers. The Ideapad Miix 700 is not just recognizably different, it also gives you great ways to work and play. A detachable Bluetooth-enabled keyboard means you can even sit apart from your Miix and still tap away. With stunning visuals and performance, the fast processor of the Ideapad Miix 700 delivers excellent processing power that allows you to work smarter.
Lenovo IdeaPad Miix 700-12ISK - 12" - Intel Core m5 - 6Y54 - 8 GB RAM - 256 GB SSD - UK
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Core m5 (6th Gen) - 6Y54 / 1.1 GHz, up to 2.7 GHz / 4 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Display
12" LED backlight touchscreen 2160 x 1440 / Full HD Plus
Graphics
Intel HD Graphics 515
Input Device
Keyboard, digitizer, touchpad, digital pen
Keyboard
802.11a/b/g/n/ac, Bluetooth 4.1
4-cell - up to 9 hours
Ambient light sensor, G-sensor, hall sensor
29.2 cm x 21 cm x 9 mm
785 g
Manufacturer Selling Program
TopSeller
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - 1 year - pick-up and return
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core m5 (6th Gen) 6Y54 / 1.1 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Integrated memory controller
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
12" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
2160 x 1440 (Full HD Plus)
Widescreen
Image Aspect Ratio
3:2
Image Brightness
400 cd/m²
Audio & Video
Graphics Processor
Sound
Stereo speakers, two microphones
High Definition Audio, Dolby Advanced Audio
Input
Keyboard Layout
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
4-cell lithium polymer
40 Wh
Run Time
Up to 9 hours
AC Adapter
Input
Output
40 Watt
Connections & Expansion
Interfaces Details
USB 2.0 , USB 3.0 , Micro-HDMI , Headphone/microphone combo jack , Keyboard
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft Office 2013 (Trial)
Case Material
Magnesium-aluminum alloy
Integrated Options
Power adapter, keyboard
RoHS
Localization
TopSeller
785 g
Dimensions (WxDxH) / Weight Details
29.3 cm x 22.4 cm x 5.5 mm / 330 g - keyboard dock
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
