Ultra simple, chic style
At just 8.9 mm thin and weighing 780 g (without its detachable keyboard), the Miix 720 has a simple, streamlined design. Its one-piece metal alloy body paired with coordinated accessories make the Miix 720 a chic complement to your busy life. Available in Champagne or Iron Gray color. -
Perfect from any angle
Providing both strength and flexibility, the Miix 720's dual watchband hinges are made from 256 individual pieces of stainless steel and are adjustable up to 150°. So whether you're watching a video, working hard, or simply using the touchscreen, you can find the perfect angle that's comfortable for you. -
Ultra crisp 12" QHD+ display
Whether you're watching videos, editing pictures, browsing the web, or reading emails, the Miix 720's stunning 12.0" display brings everything to life. With its QHD+ (2880 x 1920) configuration, it has six times as many pixels as a standard HD screen. And with more pixels, you can enjoy clearer, more detailed visuals. -
The world's fastest port
The Miix 720 comes with a Thunderbolt 3 USB-C port-the revolutionary connection technology supporting high-res displays, high-performance data devices and fast charging. Hook up your Miix 720 to multiple displays, then sync and backup at up to 40 Gbps-eight times the speed of USB 3.0! Now you can capture and edit multiple video streams in real time, or daisy-chain other devices to simplify your workflow.Connecting to a display requires a USB-C to HDMI or DisplayPort cable, depending on display interface. Connecting up to 2 displays require compatible hub/extenders. -
Laptop or tablet? You decide
Detach the 12.0" screen and use it as a lightweight Windows tablet complete with integrated kickstand...Or re-attach the keyboard for use as a powerful laptop. -
Use facial-recognition for added security
The Miix 720 provides a personal, secure way to unlock your device–without using a password. Thanks to the front-facing integrated infrared camera and Windows Hello support, your Miix 720 unlocks when it recognizes your face in front of the screen. Alternately, it auto-locks when you walk away. With Miix 720, security truly is personal. -
Set your ideas in motion with Lenovo Active Pen 2
The Lenovo Active Pen 2 is the perfect complement to your Miix 720, providing an additional way to interact, create and edit. Add a personal touch to documents by signing them with your name or annotating in your own handwriting. Take down hand-written digitized notes, or get creative by editing photos and drawing. However you choose to work, create, or communicate, the Lenovo Active Pen 2 provides more ways to express yourself. -
Everything you need to stay productive
With the responsiveness and efficiency of 7th generation Intel Core processors, you're always ready to work and play on the go. Get more done as you move quickly and easily between all your favorite apps, and take your productivity, creativity, and entertainment to the next level. -
Work smarter with Windows 10
Enjoy the best of what Windows 10 has to offer: from fast start-ups, to the expanded Start menu and all-new browser, to Cortana and Windows Ink–your very own digital personal assistant. Forget about forgetting. You can set Cortana reminders right from your Sticky Notes so your reminders go with you wherever you go. -
Access files and apps in a flash
The Miix 720 features the latest Solid State Drive (SSD) technology, allowing it to perform tasks faster than a device without SSD-including booting up, running apps, and transferring files. As well as being quieter and smaller than a standard disk drive, the durable SSD is also more likely to withstand an accidental knock or drop. -
Type with ease
Detachable and full-sized, the keyboard on the Miix 720 has backlighting to highlight each key. It also boasts 1.5 mm of key travel to feel like you're tapping away on a standard keyboard. The result? A satisfying-and hopefully more accurate-typing experience. And when you're on the move, the keyboard doubles up as a folio case to protect the screen. -
Simplicity meets accuracy
No space to use a mouse? The integrated precision touchpad can be adjusted to respond to the lightest of touches or the firmest of clicks. -
Great for photos and web chats
With its auto-focus, the rear 5 MP camera on the Miix 720 makes it a breeze to capture great moments. You can easily edit your photos via the keyboard or on screen through the Lenovo Active Pen 2–even on the go. Plus, with the built-in webcam and mic at the front, it's so simple to link up with colleagues and friends. -
All-day battery& always-on charging
With an all-day battery life, the Miix 720 won't slow you down. Whether it's crushing deadlines, catching up on social media, or simply unwinding with a movie, you'll have the power to do what you want, wherever you want. And with USB always-on charging, you can charge smartphones and other devices-even when your Miix 720 is powered off.
- Lenovo IdeaPad Miix 720-12IKB - 12" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Tablet - with detachable keyboard
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 12" LED backlight touchscreen 2880 x 1920 / QHD+
- Graphics
- Intel HD Graphics 620
- Input Device
- Digitizer, digital pen, detachable keyboard
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- 4-cell - up to 8 hours
- Black
- Dimensions (WxDxH) - tablet
- 29.2 cm x 21 cm x 0.89 cm
- 780 g
- Localisation
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
Storage
- Main Storage
- 256 GB SSD PCIe
Display
- 12" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 2880 x 1920 (QHD+)
- Widescreen
- Image Aspect Ratio
- 3:2
- Image Brightness
- 400 cd/m²
- Corning Gorilla glass
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 5 Megapixel (rear), 1 Megapixel (front)
- Camera Features
- IR camera, rear camera with auto focus
- Sound
- Speakers, two microphones
- Dolby Audio
Input
- Keyboard Layout
- UK
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - M.2 Card
- Technology
- 4-cell Lithium Ion
- Capacity
- 41 Wh
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- USB-C (charging) , USB 3.0 , USB 2.0 , Headphone/microphone combo jack , Keyboard
- Memory Card Reader
- Yes (microSD)
- Black
- Administrator password, power-on password, stand
- Included Accessories
- Power adapter, keyboard, WACOM active capacitive pen
- Localization
- 780 g
- Dimensions (WxDxH) / Weight Details
- 29.3 cm x 21.6 cm x 1.46 cm / 1.1 kg - tablet with keyboard , 29.2 cm x 21 cm x 0.89 cm / 780 g - tablet
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
