Lenovo Miix 720 12IKB i5 8GB 256GB SSD 12" Win 10 Pro
Quicklinx: D0CLWS00 Mfr#: 80VV003UUK
  • Core i5
  • IEEE 802.11n
The world's most Powerful core i tablet w/ external GFX.
  • Ultra simple, chic style
    Being very thin and light, the Miix 720 has a simple, streamlined design. Its one-piece metal alloy body makes the Miix 720 a chic complement to your busy life.
  • Perfect from any angle
    Providing both strength and flexibility, the Miix 720's dual watchband hinges are made from 256 individual pieces of stainless steel and are adjustable up to 150°. So whether you're watching a video, working hard, or simply using the touchscreen, you can find the perfect angle that's comfortable for you.
  • Ultra crisp display
    Whether you're watching videos, editing pictures, browsing the web, or reading emails, the Miix 720's stunning display brings everything to life.
  • Type with ease
    Detachable and full-sized, the keyboard on the Miix 720 has backlighting to highlight each key. It also boasts a perfect key travel to feel like you're tapping away on a standard keyboard. The result? A satisfying - and hopefully more accurate - typing experience. And when you're on the move, the keyboard doubles up as a folio case to protect the screen.
  • Simplicity meets accuracy
    No space to use a mouse? The integrated precision touchpad can be adjusted to respond to the light of touches or firm clicks.
  • Great for photos and web chats
    With its auto-focus, the rear 5 MP camera on the Miix 720 makes it a breeze to capture great moments. Plus, with the built-in webcam and mic at the front, it's so simple to link up with colleagues and friends.
  • All-day battery & always-on charging
    With an all-day battery life, the Miix 720 won't slow you down. Whether it's crushing deadlines, catching up on social media, or simply unwinding with a movie, you'll have the power to do what you want, wherever you want. And with USB always-on charging, you can charge smartphones and other devices - even when your Miix 720 is powered off.
Lenovo Miix 720-12IKB - 12" - Core i5 7200U - 8 GB RAM - 256 GB SSD - UK
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD
Display
12" LED backlight touchscreen 2880 x 1920 / QHD+
Graphics
Intel HD Graphics 620
Input Device
Digitizer, digital pen, detachable keyboard
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
4-cell - up to 8 hours
Dimensions (WxDxH) - tablet
29.2 cm x 21 cm x 0.89 cm
780 g
Limited warranty - 1 year - pick-up and return
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Integrated memory controller
RAM
8 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2133 MHz
Storage
Main Storage
256 GB SSD PCIe
Display
12" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
2880 x 1920 (QHD+)
Widescreen
Image Aspect Ratio
3:2
Image Brightness
400 cd/m²
Corning Gorilla glass
Audio & Video
Graphics Processor
Camera
Resolution
5 Megapixel (rear), 1 Megapixel (front)
Camera Features
IR camera, rear camera with auto focus
Sound
Speakers, two microphones
Dolby Audio
Input
Keyboard Backlight
Keyboard Layout
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - M.2 Card
4-cell Lithium Ion
41 Wh
Run Time
Up to 8 hours
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
USB-C (charging) , USB 3.0 , USB 2.0 , Headphone/microphone combo jack , Keyboard
Memory Card Reader
Yes (microSD)
Administrator password, power-on password, stand
Power adapter, keyboard, WACOM active capacitive pen
Localization
780 g
Dimensions (WxDxH) / Weight Details
29.3 cm x 21.6 cm x 1.46 cm / 1.1 kg - tablet with keyboard , 29.2 cm x 21 cm x 0.89 cm / 780 g - tablet
