Lenovo MIIX 520 I3-7130U 4GB 128SSD Win 10Pro
Quicklinx: DP1FWS00 Mfr#: 20M30008UK
Display Size: 12.2in, 12.2in
Processor Model: I3-7130U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 128GB
  • Core i3
  • IEEE 802.11n
10 in stock
£714.32 ex VAT
£857.18 inc VAT
Extremely portable and flexible, the Lenovo Miix 520 is designed to fit every mood. Feeling creative? Grab the Lenovo Active Pen 2 and write or draw directly on screen - even editing 3D objects scanned from your surroundings. Need to simplify your day? Let Cortana help - she can now respond to your commands from 4 meters away. Fancy some downtime? Detach the keyboard and the Miix 520 becomes a 12" multimedia-rich tablet with stunning display and crisp sound. Add powerful Quad-Core processing and LTE, and Miix is your perfect companion for every situation.
  • Intuitive versatility
    Sleeker than ever, the Miix 520 is whisper thin and effortlessly portable. Feature a modern one-piece aluminum alloy body in two sophisticated colors, 256 individual pieces to complete the unique watchband hinges providing strength and flexibility, and the ergonomic keyboard doubles as a folio case to protect your screen when you're on the move.
  • Boundless creativity
    Lenovo Active Pen 2 and Windows Ink open up a world of creativity and time-saving shortcuts. With a few strokes of the pen on screen, you will be able to post updates and comments on social media, reply to emails, generate directions in Bing Maps, and so much more. Furthermore, with the optional WorldView camera, you can now scan 3D objects, edit them, overlay them on top of a 2D photo, re-arrange their shape - and even send them to a 3D printer. It's never been easier to create, capture and share.
  • Life hacking spirit
    The Miix 520 comes equipped with optional fingerprint reader for faster and safer login. And your voice-activated digital assistant - Cortana is prepared to answer your questions, open apps, set reminders from across the room.
  • Cutting-edge performance
    The Miix 520 delivers unprecedented power for a 2-in-1. Featuring the latest Intel Quad-Core processor and up to 1 TB PCIe SSD storage, you'll enjoy exceptional performance and responsiveness, plus lightning-fast boot-ups and transfer times, anywhere. In addition, with up to 16 GB of memory, you'll be able to run more apps, larger programs, and bigger files - without fear of your Miix 520 lagging.
Lenovo Miix 520-12IKB - 12.2" - Core i3 7130U - 4 GB RAM - 128 GB SSD - UK
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit
Intel Core i3 (7th Gen) 7130U / 2.7 GHz / 3 MB Cache
4 GB DDR4 (provided memory is soldered)
Storage
128 GB SSD NVMe
Display
12.2" LED backlight touchscreen 1920 x 1200 / WUXGA
Graphics
Intel UHD Graphics 620
Input Device
Keyboard, digitizer, touchpad, digital pen
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
2-cell - up to 8 hours
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader
Iron grey
Dimensions (WxDxH) - tablet
30 cm x 20.5 cm x 0.99 cm
880 g
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Integrated memory controller
RAM
4 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
Storage
Main Storage
128 GB SSD - (M.2) PCIe - NVM Express (NVMe)
Display
12.2" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1200 (WUXGA)
Widescreen
Image Aspect Ratio
16:10
Audio & Video
Graphics Processor
Camera
Resolution
8 Megapixel (rear), 5 Megapixel (front)
Camera Features
Rear camera with auto focus
Sound
Stereo speakers, four microphones
Dolby Audio
Input
Keyboard Backlight
Keyboard Layout
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
2-cell Lithium Ion
39 Wh
Run Time
Up to 8 hours
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
USB 3.0 , USB-C 3.1 Gen 1/DisplayPort 1.2a , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Iron grey
Security
Power adapter, keyboard, Lenovo Active Pen 2
Localization
880 g
Dimensions (WxDxH) / Weight Details
30.39 cm x 21.91 cm x 0.6 cm / 380 g - keyboard dock , 30 cm x 20.5 cm x 0.99 cm / 880 g - tablet
Software applications
Lenovo MIIX 520 I3-7130U 4GB 128SSD Win 10Pro Bundle deal on Lenovo MIIX 520 I3-7130U 4GB 128SSD Win 10Pro
£893.90
saving £2.42
£813.49
DP1F Lenovo Optical 3-button W/Mouse USB In Stock £12.69
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Brand: Lenovo
Price Range Ex VAT: 500 - 750
