Keep your device unplugged for longer with the 9-cell ThinkPad Battery 70++. The average run time is 94 watt hours and the battery can be recharged with the ThinkPad External Battery Charger (40Y7625). Each power source uses Lithium-Ion technology and can be used as replacement for damaged system batteries or as a convenient spare. The battery is compatible with T410, T420, T430, T510, T520, T530, W510, W520, W530, L410, L412, L420, L421, L430, L510, L512, L520 and L530 systems.
*Battery life varies due to many factors. These include: applications, battery conditioning, features, screen brightness, power management and other customer preferences.
- Lenovo ThinkPad Battery 70++ - laptop battery - Li-Ion - 94 Wh
- Laptop battery
- 500 g
- Battery
- Lithium Ion 9-cell - 94 Wh
- Batteries Qty
- 1
- 21.852 cm x 7.845 cm x 2.12 cm
- 1-year warranty
- Designed For
- ThinkPad L410; L412; L420; L430; L510; L512; L520; L530; T410; T410i; T420; T420i; T430; T430i; T510; T510i; T520; T520i; T530; T530i; W510; W520; W530
- Laptop battery
- Quantity
- 1
- Technology
- 9-cell Lithium Ion
- Voltage Provided
- 11.1 V
- Capacity
- 94 Wh
- UL, C-Tick, cUL, PSE Mark, ACA, KC
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 8 - 95%
- 21.852 cm
- 7.845 cm
- 2.12 cm
- 500 g
- Designed For
- Lenovo ThinkPad L410 , Lenovo ThinkPad L412 , Lenovo ThinkPad L420 , Lenovo ThinkPad L430 , Lenovo ThinkPad L510 , Lenovo ThinkPad L512 , Lenovo ThinkPad L520 , Lenovo ThinkPad L530 , Lenovo ThinkPad T410 , Lenovo ThinkPad T410i , Lenovo ThinkPad T420 , Lenovo ThinkPad T420i , Lenovo ThinkPad T430 , Lenovo ThinkPad T430i , Lenovo ThinkPad T510 , Lenovo ThinkPad T510i , Lenovo ThinkPad T520 , Lenovo ThinkPad T520i , Lenovo ThinkPad T530 , Lenovo ThinkPad T530i , Lenovo ThinkPad W510 , Lenovo ThinkPad W520 , Lenovo ThinkPad W530
