Lenovo Main Battery Pack 11.1v 5600mAh
CLEARANCE!
Clearance
Price Drop
Quicklinx: 8JSXWS00 Mfr#: 0A36306
The ThinkPad battery 44+ uses advanced Lithium-Ion technology to create an efficient power source for the X230 and X220 systems. These are compatible with the X220 and X230 systems and are ideal for use as a replacement or spare. The 6-cell batteries are rechargeable and allow you to stay unplugged for longer, lasting an average of 63 watt hours. However, they are not compatible with the ThinkPad External Battery Charger (40Y7625).
*Many factors cause battery life to differ. These include: power management, features, screen brightness, applications, battery conditioning and other customer preferences.
Lenovo ThinkPad Battery 44+ - laptop battery - Li-Ion - 63 Wh
Laptop battery
345 g
Lithium Ion 6-cell - 63 Wh
20.88 cm x 5.51 cm x 2.28 cm
1-year warranty
ThinkPad X220 4287, 4289, 4290, 4291, 4293; X220i 4286, 4287, 4290; X230 2306, 2320, 2324, 2325; X230i 2320
Laptop battery
6-cell Lithium Ion
Voltage Provided
11.1 V
63 Wh
UL, C-Tick, cUL, PSE Mark, ACA, KC
Limited warranty - 1 year
5 °C
35 °C
8 - 95%
20.88 cm
5.51 cm
2.28 cm
345 g
Lenovo ThinkPad X220 4287, 4289, 4290, 4291, 4293 , Lenovo ThinkPad X220i 4286, 4287, 4290 , Lenovo ThinkPad X230 2306, 2320, 2324, 2325 , Lenovo ThinkPad X230i 2320
