Lenovo Main Battery Pack 10.8V 5800mAh 62Wh
Quicklinx: CKSZWS00 Mfr#: 0A36292
Stay unplugged for longer with the 35+ 6-cell ThinkPad x 121e, x131e and x130e battery. This rechargeable six-cell battery uses advanced lithium-ion (Li-ion) technology and can be used as a replacement for ageing system batteries or as a convenient spare. Each one is compatible with the X121e, X130e and X131e systems. The voltage is 10.8 direct current and 7.8 ampere hours while the battery life lasts for 84.24 watt hours. The battery utilises over-discharge protection to ensure a safe flow of power.
*Battery life and recharge times differ due to many factors, including: battery conditioning, screen brightness, applications, features, power management and other custom preferences.
Lenovo ThinkPad Battery 35+ - laptop battery - Li-Ion - 62 Wh
Laptop battery
320 g
Lithium Ion 6-cell - 62 Wh
21.5 cm x 5.5 cm x 2.1 cm
1-year warranty
ThinkPad X121e 3045, 3048, 3049, 3051, 3053; X130e 0622, 0627, 2338, 2339; X131e 3367, 3368, 3371, 3372; X131e Chromebook 6283; X140e 20BL, 20BM
Laptop battery
6-cell Lithium Ion
Voltage Provided
10.8 V
62 Wh
Limited warranty - 1 year
5 °C
35 °C
8 - 95%
21.5 cm
5.5 cm
2.1 cm
320 g
Lenovo ThinkPad X121e 3045, 3048, 3049, 3051, 3053 , Lenovo ThinkPad X130e 0622, 0627, 2338, 2339 , Lenovo ThinkPad X131e 3367, 3368, 3371, 3372 , Lenovo ThinkPad X131e Chromebook 6283 , Lenovo ThinkPad X140e 20BL, 20BM
