Lenovo Main Battery Pack 10.8V 5800mAh 62Wh
Quicklinx: CKSZWS00 Mfr#: 0A36292
Stock Status: Used Stock
£108.84 ex VAT
£130.60 inc VAT
Stay unplugged for longer with the 35+ 6-cell ThinkPad x 121e, x131e and x130e battery. This rechargeable six-cell battery uses advanced lithium-ion (Li-ion) technology and can be used as a replacement for ageing system batteries or as a convenient spare. Each one is compatible with the X121e, X130e and X131e systems. The voltage is 10.8 direct current and 7.8 ampere hours while the battery life lasts for 84.24 watt hours. The battery utilises over-discharge protection to ensure a safe flow of power.
*Battery life and recharge times differ due to many factors, including: battery conditioning, screen brightness, applications, features, power management and other custom preferences.
Lenovo ThinkPad Battery 35+ - laptop battery - Li-Ion - 62 Wh
Laptop battery
320 g
Lithium Ion 6-cell - 62 Wh
Batteries Qty
1
21.5 cm x 5.5 cm x 2.1 cm
1-year warranty
ThinkPad X121e 3045, 3048, 3049, 3051, 3053; X130e 0622, 0627, 2338, 2339; X131e 3367, 3368, 3371, 3372; X131e Chromebook 6283; X140e 20BL, 20BM
Laptop battery
Quantity
1
6-cell Lithium Ion
Voltage Provided
10.8 V
62 Wh
Limited warranty - 1 year
5 °C
35 °C
8 - 95%
21.5 cm
5.5 cm
2.1 cm
320 g
Lenovo ThinkPad X121e 3045, 3048, 3049, 3051, 3053 , Lenovo ThinkPad X130e 0622, 0627, 2338, 2339 , Lenovo ThinkPad X131e 3367, 3368, 3371, 3372 , Lenovo ThinkPad X131e Chromebook 6283 , Lenovo ThinkPad X140e 20BL, 20BM
Lenovo Main Battery Pack 10.8V 5800mAh 62Wh Bundle deal on Lenovo Main Battery Pack 10.8V 5800mAh 62Wh
£208.60
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: CKSZ 036480
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £15.27
Ref: CKSZ 036481
Ref: CKSZ 036482
Ref: CKSZ 036483
Ref: CKSZ 036484
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Lenovo
Price Range Ex VAT: 100 - 150
