Lenovo M73 Tiny i3-4170T 4GB 500GB Windows 10 Home
Quicklinx: BWM1WS00 Mfr#: 10AXS5S700
  • Core i3
Make your IT deployment count with the entry-level M73, an affordable-but-powerful desktop PC. Performance-boosting SSHD support, PC Cloud Manager 2, and environmental certification are just a few of the features making this PC a great choice for your enterprise.
The M73 desktop features Intel Stable Image Platform Program (SIPP), providing stability for long-term deployments to help reduce transition, qualification, and testing costs, ensuring savings for your business.
  • Platform stability
  • Hyper-fast wireless experience
    The advanced antenna design provides better signal reception and faster performance from your wireless connection.
  • PC Cloud Manager 2
    Keep your PC fleet healthy and green as you effortlessly monitor and manage your desktop's health and power consumption.
  • Fast data transfer
    Move data between the M73 and other devices quickly with USB 3.0 - it's up to 10 times faster than previous USB technologies, and is backward-compatible.
  • Green leadership
    Certifications like ENERGY STAR 5.2, EPEAT Gold, and UL Environment Gold mean you'll save money with a more energy-efficient PC. Plus, you can use Desktop Power Manager to customize your power settings and balance power consumption with system performance, helping the planet and your bottom line.
Lenovo ThinkCentre M73 - tiny - Core i3 4170T 3.2 GHz - 4 GB - HDD 500 GB
Personal computer - tiny
Intel Core i3 (4th Gen) 4170T / 3.2 GHz (Dual-Core)
Processor Socket
LGA1150 Socket
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 4400
Audio Output
Stereo
GigE
OS Provided
Windows 10 Home 64-bit Edition
Business black
17.9 cm x 18.2 cm x 3.45 cm
1.3 kg
Environmental Standards
ENERGY STAR Qualified
Personal computer
Product Form Factor
Tiny
Built-in Devices
Speaker
Business black
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1150 Socket
Chipset Type
Intel H81
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
Max Monitors Supported
2
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Preferred Pro USB
USB
Mouse
Optical
USB
Ethernet Controller
Intel I217-V
Wake on LAN (WoL)
Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe Mini Card
2 x USB 3.0 (2 in front) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 3 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort
VESA mounting kit
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, GREENGUARD
Power adapter
Power Provided
65 Watt
Efficiency
88%
Operating System / Software
OS Provided
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
17.9 cm
18.2 cm
3.45 cm
1.3 kg
