Make your IT deployment count with the entry-level M73, an affordable-but-powerful desktop PC. Performance-boosting SSHD support, PC Cloud Manager 2, and environmental certification are just a few of the features making this PC a great choice for your enterprise.
The M73 desktop features Intel Stable Image Platform Program (SIPP), providing stability for long-term deployments to help reduce transition, qualification, and testing costs, ensuring savings for your business.
Platform stability
The M73 desktop features Intel Stable Image Platform Program (SIPP), providing stability for long-term deployments to help reduce transition, qualification, and testing costs, ensuring savings for your business. -
Hyper-fast wireless experience
The advanced antenna design provides better signal reception and faster performance from your wireless connection. -
PC Cloud Manager 2
Keep your PC fleet healthy and green as you effortlessly monitor and manage your desktop's health and power consumption. -
Fast data transfer
Move data between the M73 and other devices quickly with USB 3.0 - it's up to 10 times faster than previous USB technologies, and is backward-compatible. -
Green leadership
Certifications like ENERGY STAR 5.2, EPEAT Gold, and UL Environment Gold mean you'll save money with a more energy-efficient PC. Plus, you can use Desktop Power Manager to customize your power settings and balance power consumption with system performance, helping the planet and your bottom line.
- Lenovo ThinkCentre M73 - tiny - Core i3 4170T 3.2 GHz - 4 GB - SSD 120 GB
- Personal computer - tiny
- Processor
- Intel Core i3 (4th Gen) 4170T / 3.2 GHz (Dual-Core)
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 120 GB - SATA 6Gb/s
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 4400
- Audio Output
- Stereo
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Home 64-bit Edition
- Business black
- 17.9 cm x 18.2 cm x 3.45 cm
- 1.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Personal computer
- Product Form Factor
- Tiny
- Built-in Devices
- Speaker
- Business black
Processor / Chipset
- CPU
- Clock Speed
- 3.2 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel H81
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- SSD
- Capacity
- 1 x 120 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Preferred Pro USB
- Interface
- USB
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I217-V
- Data Link Protocol
- Wake on LAN (WoL)
- Slots
- 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe Mini Card
- 2 x USB 3.0 (2 in front) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 3 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS, GREENGUARD
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 88%
Operating System / Software
- OS Provided
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- 17.9 cm
- 18.2 cm
- 3.45 cm
- 1.3 kg
