Lenovo M53 Thinclient Intel BayTrail Celeron J1800 2GB 16GB Win 7
Quicklinx: BXNLWS00 Mfr#: 10ED0004UK
  • Celeron
For large enterprise(EDU/GOV/PUB etc.) with a need for an essential desktop PC, the ThinkCentre M53 provides the just enough performance at a competitive price without sacrificing security, stability, manageability, and green environment. Moreover, 1L small size tiny formfactor help customer save both work space and storage space for IT managers. The flexibility on mounting solutions across all the Tinys also simplify the complexity of IT environment.
  • Tiny form factor
    The tiny desktops were the first 1L desktop in the industry. Complete with flexible mounting solutions, including support for standard VESA mounts, Tiny desktops fit just about anywhere, yet they provide a reliable, enterprise-level performance that you can depend on.
  • Keyboard power-on
    If you choose to mount this compact unit on the back of your monitor, you can still power on conveniently from the front, by simply pressing Alt+P on a USB-connected keyboard. Also compatible with wireless keyboards.
  • Advanced thermal design
    The Intelligent Cooling Engine (ICE) 3.0 is designed to provide a balance between thermals and acoustics, resulting in long desktop life. Choose the performance mode that best suits your work environment, prioritizing temperature or sound. Plus, ICE 3.0 allows for working in hotter temperatures and enables system monitoring with thermal alerts that preempt overheating possibilities, so you don't have to worry about business continuity.
  • USB power and blocking
    M53 includes an always-on USB port with Rapid Charge, so you can charge your devices without having to power on your PC. Also, Smart USB Protection means you can block external storage devices, allowing only keyboard or mouse peripherals and protecting your valuable data.
  • Three-year stable chassis design
    The M53 desktop provides stability for long-term deployments to help reduce transition, qualification, and testing costs, ensuring savings for your business.
  • Hyper-fast wireless experience
    The advanced antenna design provides better signal reception and faster performance from your wireless connection.
  • Fast data transfer
    Move data between the M53 and other devices quickly with USB 3.0 - it's up to 10 times faster than previous USB technologies, and is backward-compatible.
  • Green leadership
    Certifications like ENERGY STAR and EPEAT Gold mean you'll save money with a more energy-efficient PC. Plus, you can use Desktop Power Manager to customize your power settings and balance power consumption with system performance, helping the planet and your bottom line.
Lenovo ThinkCentre M53 - tiny - Celeron J1800 2.41 GHz - 2 GB - flash 16 GB - UK
Thin client - tiny - administrator password, hard drive password, power-on password, boot without keyboard or mouse, USB port control, boot sequence control, 1 USB 3.0 (Always On)
1 x Intel Celeron J1800 / 2.41 GHz (, up to 2.58 GHz, (Dual-Core)
Cache Memory
1 MB
Cache Per Processor
1 MB
RAM
2 GB (installed) / 8 GB (max) - DDR3L SDRAM
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
Flash 16 GB
Graphics Controller
Intel HD Graphics
Audio Output
Stereo
GigE
Keyboard
OS Provided
Microsoft Windows Embedded Standard 7
Business black
17.9 cm x 18.2 cm x 3.45 cm
1.3 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Thin client
Product Form Factor
Tiny
Built-in Devices
Speaker
Business black
Processor / Chipset
CPU
Intel Celeron J1800
Clock Speed
2.41 GHz
Max Turbo Speed
2.58 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
1 MB
Cache Per Processor
1 MB
RAM
Installed Size
2 GB / 8 GB (max)
DDR3L SDRAM
Effective Memory Speed
1333 MHz
SO-DIMM 204-pin
Slots
1 (Total) / 0 (empty)
Configuration Features
1 x 2 GB
Hard Drive
Flash
1 x 16 GB
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Channel Qty
1
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel HD Graphics
Video Interfaces
VGA, DisplayPort
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Preferred Pro USB
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111GN
Wake on LAN (WoL)
Slots
1 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x CPU
4 x USB 2.0 (1 in front) , 1 x USB 3.0 (1 in front) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort
Administrator password, hard drive password, power-on password, boot without keyboard or mouse, USB port control, boot sequence control, 1 USB 3.0 (Always On)
Theft/Intrusion Protection
RoHS, GREENGUARD
TopSeller
Power adapter
Power Provided
65 Watt
Efficiency
88%
Operating System / Software
OS Provided
Sustainability Information
ENERGY STAR Certified
17.9 cm
18.2 cm
3.45 cm
1.3 kg
