Lenovo M Series Tower Ci5-7400 4GB 500GB DVDRW Win 10 Pro
Quicklinx: CXVBWS00 Mfr#: 10M90004UK
  • Core i5
Maximize productivity with independent display support for up to two monitors. The expanded work area and easier navigation between applications helps reduce errors and improve productivity as you extend your desktop across multiple monitors.
Lenovo Desktop Power Manager enables professional-level power monitoring, putting you in control of saving energy and keeping costs down. Plus, with ratings like ENERGY STAR 6.1, ULE Gold, EPEAT Gold, and 85% efficiency with 80+ Platinum power supply unit (PSU), you can feel good about helping the planet and your bottom line.
Personal computer
Product Form Factor
Tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Intel Core i5 (7th Gen) 7400 / 3 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Processor Main Features
Intel Turbo Boost Technology 2
Chipset Type
Intel B250 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 64 GB (max)
DDR4 SDRAM - non-ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
Optical Storage
DVD-Writer - SATA
Card Reader
7 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel HD Graphics 630
Video Interfaces
VGA, DisplayPort
Max Monitors Supported
3
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
USB
Ethernet Controller
Realtek RTL8111GN
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" Slim Line ¦ 2 (total) / 1 (free) x internal 3.5" x 1/3H
Slots
4 (total) / 3 (free) x DIMM 288-pin ¦ 1 (total) / 0 (free) x CPU ¦ 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height ¦ 2 (total) / 2 (free) x PCIe 3.0 x1 - half-length, full-height
6 x USB 3.0 (4 front, 2 rear) ¦ 2 x microphone (1 front, 1 rear) ¦ 1 x headphones (1 in front) ¦ 2 x USB 2.0 ¦ 1 x serial ¦ 1 x LAN (Gigabit Ethernet) ¦ 1 x VGA ¦ 2 x DisplayPort ¦ 1 x PS/2 keyboard ¦ 1 x PS/2 mouse ¦ 1 x audio line-in ¦ 1 x audio line-out ¦ 1 x parallel
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, cable lock, chassis intrusion switch
Security Slot Type
Kensington security slot
RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
Manufacturer Selling Program
TopSeller
Power supply
Nominal Voltage
Power Provided
180 Watt
Efficiency
85%
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition
Software
Cyberlink PowerDVD, Lenovo Companion, PowerDVD Create, Lenovo ID
Environmental Standards
ENERGY STAR Certified
ENERGY STAR Version
6.1
Limited warranty - 3 years - on-site
14.5 cm
29.27 cm
36.6 cm
6.5 kg
Keyboards and Mice (1)
CXVB Lenovo Optical 3-button W/Mouse USB In Stock £12.69
Other bundles (1)
CXVB Lenovo Microsaver Security Cable Lock In Stock £34.15
