Powered by advanced processors, a ThinkCentre M710 tower is designed for speed, responsiveness, and efficiency - three key features that can help propel your business. Hardwired into every ThinkCentre M710 tower is the TPM (Trusted Platform Module). This international standard for securing hardware gives you extra peace of mind should the PC ever fall into the wrong hands or someone tries to tamper with it.
Tiny footprint, big statement
Being smaller, the M710 is extremely compact. This tiny desktop fits just about anywhere and can be positioned horizontally or vertically - mount it on a wall, behind a monitor, or even under a desk. You can even power digital signage with a PC, that's easy to hide from view. It delivers reliable, professional-level performance, while freeing up valuable desk-space. -
The benefits of modular design
With the ThinkCentre M710, you can create your own modular all-in-one PC. Simply use the M710 inside the back of the display. Keep costs down when choosing to upgrade the display and computing power separately, and get more use from your assets over time. -
Packs a punch
The ThinkCentre M710 features a small footprint yet delivers heavyweight performance. With up to three independent displays, or four displays in Mosaic mode, this tiny PC expands the limits of desktop computing to enable greater productivity. Ideal for financial and creative industries - and all your multimedia, multitasking needs. -
Bigger isn't necessarily better
Don't be deceived by its miniature frame, as the ThinkCentre M710 punches well above its weight. Equipped with an excellent processor and extensive storage, you can power up in a flash and load files even faster. Intensive tasks like multimedia creation, graphic design, and number-crunching are a walk in the park. -
Built for business
The ThinkCentre M710 is built to last in any environment. It carries the Think name, which means it's proved against military-specification requirements. From enduring arctic temperatures of -20 degrees C, to desert heat of 60 degrees C, this device can more than handle the bumps and bruises of life.
- Lenovo ThinkCentre M710q - tiny - Core i5 7400T 2.4 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - tiny
- Localisation
- Processor
- Intel Core i5 (7th Gen) 7400T / 2.4 GHz (, up to 3 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 630
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Black
- 17.9 cm x 18.29 cm x 3.45 cm
- 1.32 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Tiny
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.4 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel B250
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- Max Monitors Supported
- 3
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- Lenovo Calliope Mouse
- Interface
- USB
- Ethernet Controller
- Intel I219-V
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- Wake on LAN (WoL)
- Bays
- 1 (total) / 0 (free) x internal 2.5"
- Slots
- 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x M.2 Card
- 6 x USB 3.1 Gen 1 (2 front, 4 rear) (one of them is Always On and fast-charging) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort , 1 x VGA , 1 x serial
- Included Accessories
- VESA mounting kit, adapter cage
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion switch, tool-less chassis access
- Security Slot Type
- Kensington security slot
- RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
- TopSeller
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 88%
Operating System / Software
- OS Provided
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 17.9 cm
- 18.29 cm
- 3.45 cm
- 1.32 kg
