Lenovo M Series Tiny Ci3-7100T 4GB 500GB Windows 10 Pro
Quicklinx: CXV3WS00 Mfr#: 10MR0021UK
Processor Type: Core i3
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB
Hard Drive Capacity: 500GB, 500GB
Storage Type: HDD
  • Core i3
£378.24 ex VAT
£453.88 inc VAT
Rugged, powerful, and astonishingly compact. The 1L ThinkCentre M Series Tiny desktop is MIL-SPEC tested, so it can handle tough treatment, including dusty environments. And while it boasts cutting edge features, it’s small enough to be deployed anywhere.
  • Tiny footprint, big statement
    At 96% smaller than a traditional desktop tower, the M710 Tiny is extremely compact. This tiny desktop fits just about anywhere and can be positioned horizontally or vertically - mount it on a wall, behind a monitor, or even under a desk. You can even power digital signage with a PC that's easy to hide from view. It delivers reliable, professional-level performance, while freeing up valuable desk-space.
  • The benefits of modular design
    With the ThinkCentre M710 Tiny, you can create your own modular all-in-one PC. Keep costs down when choosing to upgrade the display and computing power separately, and get more use from your assets over time.
  • Packs a punch
    The ThinkCentre M710 features a small footprint yet delivers heavyweight performance. With up to three independent displays, or four displays in Mosaic Mode, this Tiny PC expands the limits of desktop computing to enable greater productivity. Ideal for financial and creative industries - and all your multimedia, multitasking needs.
  • Bigger isn't better
    Don't be deceived by its miniature frame, as the ThinkCentre M710 Tiny punches well above its weight. You can power up in a flash and load files even faster. Intensive tasks like multimedia creation, graphic design, and number-crunching are a walk in the park.
  • Built for business - tested for your lifestyle
    The ThinkCentre M710 Tiny is built to last in any environment. It carries the Think name, which means it's tested against military-specification requirements, as well as 200 rigorous quality checks. This device can more than handle the bumps and bruises of life.
Lenovo ThinkCentre M710q - tiny desktop - Core i3 7100T 3.4 GHz - 4 GB - 500 GB
Personal computer - tiny desktop
1 x Intel Core i3 (7th Gen) 7100T / 3.4 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 630
GigE
OS Provided
17.9 cm x 18.29 cm x 3.45 cm
1.32 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
Tiny desktop
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel B250
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Max Monitors Supported
2
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Ethernet Controller
Intel I219-V
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x M.2 Card
6 x USB 3.1 Gen 1 (2 front, 4 rear) (one of them is Always On and fast-charging) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort
Vertical stand
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion switch
Security Slot Type
Kensington security slot
RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
Power adapter
Nominal Voltage
Power Provided
65 Watt
Efficiency
88%
Operating System / Software
OS Provided
ENERGY STAR Certified
ENERGY STAR Version
6.1
17.9 cm
18.29 cm
3.45 cm
1.32 kg
Lenovo M Series Tiny Ci3-7100T 4GB 500GB Windows 10 Pro Bundle deal on Lenovo M Series Tiny Ci3-7100T 4GB 500GB Windows 10 Pro
£560.75
saving £8.33
£471.27
Keyboards and Mice (1)
CXV3 Lenovo Optical 3-button W/Mouse USB In Stock £13.60
Other bundles (1)
CXV3 Lenovo Microsaver Security Cable Lock In Stock £23.87
Storage Type: HDD
Processor Model: I3-7100T
Type: Personal computer
Case Style: Ultra small form factor
Display: not included
Optical Storage: None
Brand: Lenovo
Price Range Ex VAT: 300 - 500
