Lenovo Legion Y25-25 24.5" 1920x1080 1ms HDMI
Quicklinx: GTDJWS00 Mfr#: 66AAGAC6UK
Professional Esport gaming is an extremely competitive space - where the difference between winning and losing comes down to the minutest of details. To stand out from the competition, you need equipment that matches the speed of your thought and actions. The Legion Y25-25 delivers wins in the toughest, most critical situations. Its 24.5-inch In-Plane Switching (IPS) panel with a 240 Hz refresh rate and 1 ms response time makes it possible to spot an opponent before they see you. When it comes down to quick-fire duel, that is the difference between firing first and getting shot.
  • Exceptionally smooth gameplay
    Elite pro gamers are fast. They can make up to 600 actions per minute (APM) in the highest levels of Esports, and only purpose-built monitors can keep up with such savagery. With its extreme 1ms response time to its insane 240 Hz refresh rate, the Y25 doesn't just keep up but does a lot more. It nearly eliminates screen tearing, streaking, ghosting, and stuttering, ensuring uninterrupted, smooth gameplay, no matter how fast you move in-game. Built for those engaged in vast, multiplayer battles at the tournament level, the Y25 offers a 24.5-inch, FHD, IPS panel with built-in AMD Radeon Freesync within a striking 3-side NearEdegless chassis.
  • Superlative clarity
    Whether engaging multiple opponents in a fast-paced race in the outback or trawling post-apocalyptic wastelands under the cover of nuclear winter hunting zombies, the monitor plays an important role in making sure you are going at the right target and seeing your enemies clearly. The stakes are high in a tournament setting, and the Legion Y25-25 presents every little detail in a way that makes games more natural to follow on-screen. In-Plane Switching offers wide viewing angles that do not distort images on-screen, regardless of where you see it from. With HDR decoding that restores the original picture quality and 400 nits of brightness, games look exactly as designed - bright, vibrant, and uncorrupted. The panel's 99% sRGB color gamut reproduces colors accurately, be it in light or shadow, so you always get excellent visuals.
  • Practical connectivity
    There is more than one way to connect your Legion Y25- 25 to a PC or gaming console that allows high-speed data transfers. Additionally, you have the option to access data from external devices using the four in-built USB 3.0 (2 with BC 1.2) ports. The audio out jack offers an easy way to connect your external speakers or other audio devices for a sublime audio-visual experience. A hook on the side of the monitor gives you a spot to conveniently hang your headphones within arm's reach.
  • Exemplary operational comfort
    A monitor's ergonomics are vital to keeping players comfortable through fast-paced and highly immersive gameplay. The Y25-25 is built to make sure you experience close to zero strain. Its stand comes with multiple tilting, pivoting, swiveling, or lifting functions so that you can fine tune it to precisely suit your style. The monitor is also TÜV Rheinland Eye Comfort-certified, meaning your eyes are protected from harmful blue light radiation, flickering screens, and external reflections, allowing you to game stress-free.
Lenovo Legion Y25-25 - LED monitor - Full HD (1080p) - 24.5"
LED-backlit LCD monitor - 24.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/339722
Energy Class
Class F
Power Consumption (On mode)
19 W
Adaptive-Sync Technology
NVIDIA G-SYNC Compatible, AMD FreeSync Premium
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 240 Hz
Pixel Pitch
0.2832 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
1 ms (extreme), 3 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Raven black
55.87 cm x 25.05 cm x 38.25 cm
5.59 kg
EMEA
CCC, Directive 2002/95/EC, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
24.5"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2832 mm
Pixel Per Inch
90
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
3-sided bezeless, 8-bit Colour Depth, 3-side NearEdgeless, 99% sRGB colour gamut
Raven black
55.87 cm x 25.05 cm x 38.25 cm - with stand
5.59 kg
USB 3.2 Gen 1 upstream , 2 x USB 3.2 Gen 1 downstream , 2 x USB 3.2 Gen 1 downstream with Battery Charging 1.2 , DisplayPort , HDMI , Audio line-out
Mechanical
Tilt Angle
-5/+22
Swivel Angle
60
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, integrated headphone hook
1 x DisplayPort cable - 1.8 m , 1 x USB-B to USB-A cable - 1.8 m
EMEA
Security Slot Type
Kensington security slot
Input Voltage
19 W
19 kWh/1000h
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Lenovo Display Control Center
Microsoft Windows 7 / 10
Dimensions & Weight Details
With stand (lowest position) - width: 55.87 cm - depth: 25.05 cm - height: 38.25 cm - weight: 5.59 kg , With stand (highest position) - width: 55.87 cm - depth: 25.05 cm - height: 51.25 cm - weight: 5.59 kg , Without stand - width: 55.87 cm - depth: 5.95 cm - height: 33.5 cm - weight: 3.61 kg
Shipping Width
65.2 cm
Shipping Depth
19.5 cm
Shipping Height
42.7 cm
Shipping Weight
7.53 kg
Limited warranty - 3 years
