Lenovo Laser Wireless Mouse
Quicklinx: C0TWWS00 Mfr#: 0A36188
The portable, ambidextrous Lenovo Wireless Laser Mouse is perfect for anyone looking for a compact mouse to use every day and while on-the-go. Scroll through documents, spreadsheets, and more with increased accuracy and control with its high-definition laser sensor. An advanced power management system, a high-efficiency laser sensor, and an off switch help to maximize your battery life.
Lenovo - mouse - 2.4 GHz - Campus
Mouse
Wireless - 2.4 GHz
5.6 cm x 9.6 cm x 3.2 cm
108 g
Worldwide (excluding Argentina, Brazil, Korea, Paraguay)
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Movement Resolution
1600 dpi
Scrolling wheel (4-way), battery indicator
2 x AA type
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Manufacturer Selling Program
Lenovo Campus
1-year warranty
Mouse
Wireless Receiver
5.6 cm
9.6 cm
3.2 cm
108 g
Input Device
Wireless
2.4 GHz
Laser
Movement Resolution
1600 dpi
1 x USB - 4 pin USB Type A
C-Tick, IC, DOC, MOC, FCC, R&TTE, NTRA, KCC, ANATEL, TELEC
Lenovo Campus
AA type
Installed Qty
2
Limited warranty - replacement - 1 year
20 - 95%
