Lenovo L560 Core i5-6200U 4GB 500GB 15.6"  Windows 7 Professional
Quicklinx: CFHLWS00 Mfr#: 20F10025UK
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Performance and portability come together in the ThinkPad L560. A great choice for on-the-go professionals. The thin and light L560's features include long battery life, robust connectivity, optimized performance, and business-class manageability and security features.
  • Thin and light design
    With its thin and light design, the L560 is a great choice for on-the-go professionals.
  • Robust connectivity
    Despite being thin and light, the L560 has the ports to connect to the devices you need to get the job done.
  • Long battery life
    With a long battery life, the L560 will keep your business online even when plug-in power is not on tap.
  • Ultra durable
    The L560 offers ruggedness and durability against conditions such as high pressure, humidity, vibration, high temperature, temperature shock, low pressure, low temperature, and dust.
  • Responsive performance
    With plenty of memory, you can run multiple high-end software applications without stalling your PC.
Lenovo ThinkPad L560 - 15.6" - Intel Core i5 - 6200U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD-Writer
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 520
Input Device
TrackPoint, UltraNav
Keyboard
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
6-cell - up to 11.2 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
37.7 cm x 25.5 cm x 3.085 cm
2.38 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Optical Drive
DVD-Writer - tray
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Codec
Realtek ALC3245
High Definition Audio
Input
Keyboard, TrackPoint, UltraNav
Keyboard Layout
Numeric Keypad
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Wireless Broadband (WWAN)
Generation
WWAN upgradable
6-cell Lithium Ion
48 Wh
Run Time
Up to 11.2 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Slots
1 x ExpressCard/34 (1 free)
Interfaces Details
4 x USB 3.0 , VGA , Mini DisplayPort , LAN , Dock , Headphone/microphone combo jack
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
ThinkVantage Rescue and Recovery, Adobe Reader, ThinkVantage System Update, ThinkVantage Product Recovery, Lenovo Solution Center, McAfee LiveSafe (30 days trial)
Case Material
Polycarbonate ABS
Dockable
Security
Administrator password, hard drive password, power-on password, ThinkVantage Active Protection System, 1 USB 3.0 (Always On), ThinkEngine, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
RoHS, GREENGUARD
Localization
TopSeller
2.38 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
CFHL C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black In Stock £17.40
