Lenovo L460 Core i5-6200U 4GB 192GB SSD 14" Windows 7 Pro
Quicklinx: CFHHWS00 Mfr#: 20FU001LUK
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
With memory, you can run multiple high-end software applications without stalling your PC. Visuals look great on the ThinkPad L460, thanks to integrated Intel HD graphics. Whether you're creating presentations, writing reports, or kicking back with a movie, the L460 fits the bill.
At just 0.96" thin and weighing in at as little as 1.9 kg, the L460 is a great choice for on-the-go professionals. But, the L460 is also durable. It meets 12 US military-spec tests for ruggedness, durability, and quality. In addition, innovative roll-cage technology and glass-fiber reinforced plastic add extra strength and rigidity.
  • Enhanced graphics performance
    Visuals look great on the ThinkPad L460, thanks to the powerful discrete graphics chip. Whether you’re assembling video presentations, editing product photos, or kicking back with a movie, the L460 fits the bill.
  • Thin and light design
    Being extremely thick and lightweight, the L460 is a great choice for on-the-go professionals.
  • Long battery life
    Thanks to its stunning battery life, the L460 will keep your business online even when plug-in power is not on tap.
  • Ultra durable
    The L460 ensures ruggedness, durability, and quality under the conditions of high pressure, humidity, vibration, high temperature, temperature shock, low pressure, low temperature, and dust.
  • Robust connectivity
    Despite being thin and light, the L460 has the ports you need to connect to the devices you need to get the job done.
  • Responsive performance
    With capacitive memory, you can run multiple software applications without stalling your PC.
Lenovo ThinkPad L460 - 14" - Intel Core i5 - 6200U - 4 GB RAM - 192 GB SSD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
192 GB SSD
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Input Device
TrackPoint, UltraNav
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
6-cell - up to 12.7 hours
Dockable
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
33.9 cm x 23.5 cm x 2.43 cm
2.02 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
32 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
192 GB SSD SATA 6Gb/s
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Codec
Realtek ALC3245
High Definition Audio
Input
Keyboard, TrackPoint, UltraNav
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Wireless Broadband (WWAN)
Generation
WWAN upgradable
6-cell Lithium Ion
48 Wh
Run Time
Up to 12.7 hours
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
Interfaces Details
3 x USB 3.0 , Mini DisplayPort , VGA , LAN , Headphone/microphone combo jack , Dock
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
ThinkVantage Rescue and Recovery, Adobe Reader, ThinkVantage System Update, ThinkVantage Product Recovery, Lenovo Solution Center, McAfee LiveSafe (30 days trial)
Case Material
Polycarbonate ABS
Dockable
Security
Security lock slot (cable lock sold separately), administrator password, hard drive password, power-on password, 1 USB 3.0 (Always On), ThinkEngine, MIL-STD-810G tested
Power adapter
RoHS, GREENGUARD
Localization
TopSeller
2.02 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
CFHH C2G 20cm Mini DisplayPort Male to HDMI Female Adapter Black In Stock £16.62
CFHH C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black In Stock £17.63
