Meet the Ideapad 330s. Thinner & lighter with narrow bezels for broader viewing, it boasts state-of-the-art processing and accelerated graphics performance. Power through any task with ease.
Simple, sleek, & premium
Featuring a streamlined chassis with a polished aluminum cover, the Ideapad 330s is designed to make an impression.
Designed with you in mind
We’ve placed the power button back on the upper right-hand side of the keyboard for quick access—and added a backlit numeric keyboard option for ease of use.
Rapid Charge, any time
We know you’ve got stuff to do—who wants to be chained to an outlet? The Ideapad 330s not only boasts up to 7 hours of battery life, it also offers Rapid Charge: 15 minutes plugged in will give you up to 2 hours of battery life.* Charge up quickly, and get back to your day.
*In power-off mode. 65 W power supply required.
Windows 10 keeps getting better
Leverage the best of Windows 10, with a new update packed with exciting features. The powerfully reimagined Photos app makes it easier—and more fun—to tell your story in video: add a soundtrack, use transitions, deploy 3D effects, and more. And sharing is quicker than ever, with intuitive settings that make it easier to instantly connect with the people you care about most.
Cleaner, safer preload
We are committed to providing an uncluttered desktop and a safer PC experience out of the box. Our preload contains just five hand-selected applications designed to increase your productivity.
Lifelike clarity
Featuring up to FHD resolution on a wide-angle display edged with razor-thin 5.9 mm bezels, the Ideapad 330s offers the dynamic experience of a portable home theater.
Rich, warm sound of Dolby Audio™
With Dolby Audio, the Ideapad 330s dramatically enhances your entertainment experience. Turn up the volume without distortion—you’ll hear every detail.
Simple, sleek,& premium
Featuring a streamlined chassis with a polished aluminum cover, the Ideapad 330S is designed to make an impression. Choose from a range of sophisticated tone-on-tone color options to make it yours. Designed with you in mind We've placed the power button back on the upper right-hand side of the keyboard for quick access-and added a backlit numeric keyboard option for ease of use -
Amp up your productivity
Over 4 years and 2 million hours of engineering went into the development of the latest AMD Ryzen processors. AMD combined that technology with the world's most anticipated graphics engines to create the AMD Ryzen Accelerated Processing Unit. Whether you're working or playing, you'll experience optimized power, performance, and speed. Accelerated graphics performance Binge watch your favorite shows, dive into intensive editing tasks, and play your favorite games-with up to an AMD Radeon 540 discrete graphics card. Coupled with Radeon FreeSync technology, you'll experience a smooth and stutter-free experience.**Available with Ryzen processor models -
We know you've got stuff to do-who wants to be chained to an outlet? The Ideapad 330S not only boasts up to 7 hours' battery life, it also offers Rapid Charge: 15 minutes plugged in will give you up to 2 hours of battery life.* Charge up quickly, and get back to your day.*In power-off mode. 65 W power supply required. Windows 10 keeps getting better Leverage the best of Windows 10, with a new update packed with exciting features. The powerfully reimagined Photos app makes it easier-and more fun-to tell your story in video: add a soundtrack, use transitions, deploy 3D effects, and more. And sharing is quicker than ever, with intuitive settings that make it easier to instantly connect with the people you care about most. -
We are committed to providing an uncluttered desktop and a safer PC experience out of the box. Our preload contains just five hand-selected applications designed to increase your productivity. Lifelike clarity Featuring up to FHD resolution on a wide-angle display edged with razor-thin 5.9 mm bezels, the Ideapad 330S offers the dynamic experience of a portable home theater. -
With Dolby Audio, the Ideapad 330S dramatically enhances your entertainment experience. Turn up the volume without distortion-you'll hear every detail. Ample storage for your photos, movies,& more The Ideapad 330S can be customized to fit all your storage needs. Up to 2 TB SATA HDD stores thousands of videos, photos and files. Responsive PCIe SSD– up to 256 GB– features shorter boot-up times and faster data transfer speeds. And 128 GB PCIe SSD + 1 TB SATA HDD hybrid storage offers a great mix of both options.
- Lenovo IdeaPad 330S-15ARR - 15.6" - AMD Ryzen 3 - 2200U - 4 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- AMD Ryzen 3 2200U / 2.5 GHz, up to 3.4 GHz / 4 MB Cache
- Memory
- 4 GB DDR4 (provided memory is soldered)
- Storage
- 128 GB SSD
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- AMD Radeon Vega 3
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- Up to 8 hours
- Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip
- Platinum grey
- 35.84 cm x 24.41 cm x 1.94 cm
- 1.87 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 4 GB (provided memory is soldered)
- Max RAM Supported
- 8 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- AMD Radeon Vega 3
- Camera
- Yes - 720p
- Resolution
- 1 Megapixel
- Sound
- Stereo speakers, dual array microphone
- High Definition Audio, Dolby Audio Premium
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Technology
- Lithium Ion
- Capacity
- 52.5 Wh
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Interfaces Details
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , USB-C 3.1 Gen 1 , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Platinum grey
- Case Material
- Aluminum, polycarbonate ABS
- Security
- Administrator password, hard drive password, power-on password, RapidCharge
- Theft/Intrusion Protection
- Security Slot Type
- Kensington mini security slot
- Included Accessories
- Power adapter
- RoHS
- Localization
- 1.87 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
