The affordable Lenovo ideapad 110 notebooks combine a slim 22.9 mm design with features such as an integrated DVD drive and Intel processor, offering great performance at a great price.
Powered for fun
The Ideapad 110 is powered by an advanced processor with integrated graphics, giving you plenty of processing power for casual surfing, streaming, and playing. -
Lightning-fast web browsing
802.11 a/c Wi-Fi connectivity comes standard on the Ideapad 110, making it perfect for blazing-fast browsing, streaming, and downloading. 802.11 a/c Wi-Fi delivers up to 3 times the connection speeds of 802.11 b/g/n. -
Productivity and comfort
The Ideapad 110 has a number of features to maximize your productivity and comfort. The improved hinge design is more robust and allows for smooth 180-degree action to a flat position. The frameless keyboard allows your fingers to move freely without bumping, and the textured palm rest resists fingerprints and helps keep your hands in place without slipping - perfect for speedy touch-typing. -
Plenty of Storage
With spacious HDD storage, you won't have to worry about where to put all your data, videos, music, or photos.
- Lenovo IdeaPad 110-15IBR - 15.6" - Intel Celeron - N3060 - 4 GB RAM - 1 TB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit - English
- Processor
- Intel Celeron N3060 / 1.6 GHz, up to 2.48 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 1 TB HDD / 5400 rpm
- Optical Drive
- DVD-Writer
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 400
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, 10/100 Ethernet
- Battery
- 3-cell - up to 3 hours
- Black
- 37.8 cm x 26.5 cm x 2.29 cm
- 2.2 kg
- Localisation
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.48 GHz
- Number of Cores
- Dual-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Integrated memory controller, Intel Burst Technology
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3-12800
- Rated Speed
- 1600 MHz
Storage
- Main Storage
- 1 TB HDD SATA 6Gb/s / 5400 rpm
- Optical Drive
- DVD-Writer - tray
Display
- 15.6" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 0.3 Megapixel
- Sound
- Stereo speakers, microphone
- Dolby Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3165
- Network Interface
- 10/100 Ethernet
- Technology
- 3-cell lithium polymer
- Capacity
- 24 Wh
- Run Time
- Up to 3 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- USB 3.0 , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Black
- Case Material
- Polycarbonate ABS
- Administrator password, hard drive password, power-on password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington mini security slot
- Included Accessories
- Power adapter
- RoHS
- Localization
- 2.2 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
