The affordable Lenovo IdeaPad 100 notebooks combine a slim 22.9 mm design with features including an integrated DVD drive and an Intel processor and Nvidia 920M graphics.
Engineered for value
Everything you need. Nothing you don't. If you're looking for an affordable laptop that doesn't sacrifice on performance, the Ideapad 100 is the notebook for you. -
Thin, light, and portable
Never lug a heavy, clunky laptop around again. With its compact size and light weight, the Ideapad 100 is perfect for an on-the go lifestyle. -
Convenient connectivity
With Wi-Fi connectivity and Bluetooth 4.0, you can connect to the Internet wherever you go
- Lenovo IdeaPad 100-15IBD - 15.6" - Intel Core i3 - 5005U - 8 GB RAM - 1 TB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit - English
- Processor
- Intel Core i3 (5th Gen) - 5005U / 2 GHz / 3 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 1 TB HDD / 5400 rpm
- Optical Drive
- DVD-Writer
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 5500
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet
- Battery
- 4-cell
- Black
- 37.8 cm x 26.5 cm x 2.26 cm
- 2.3 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i3 (5th Gen) 5005U / 2 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 1 TB HDD SATA 6Gb/s / 5400 rpm
- Optical Drive
- DVD-Writer - tray
Display
- 15.6" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 0.3 Megapixel
- Sound
- Speaker, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Numeric Keypad
Communications
- Wireless
- Wireless Controller
- Realtek RTL8723BE - PCI Express Mini Card
- Network Interface
- 10/100 Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 32 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- USB 3.0 , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Black
- Security lock slot (cable lock sold separately), administrator password, hard drive password, power-on password
- Included Accessories
- Power adapter
- RoHS
- Localization
- TopSeller
- 2.3 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
