Lenovo HDMI to VGA Monitor Adapter
Quicklinx: C2XYWS00 Mfr#: 0B47069
More than 50 In Stock
£23.20 ex VAT
£27.84 inc VAT
The 20 cm HDMI to VGA adapter provides the best sleek compatibility experience as it seamlessly enables interoperability of ThinkPad systems with commercial analog projectors and displays. The small form factor HDMI to VGA adapter allows you to connect to an extended display or work in mirrored mode with VGA projectors.
Lenovo adapter - HDMI / VGA - 20 cm
Cable
Adapter - HDMI / VGA
Length
20 cm
Connector
HDMI - male
Connector (Second End)
HD-15 (VGA) - female
Cable Type
Adapter
Interface Supported
HDMI / VGA
Length
20 cm
Connector
19 pin HDMI Type A - male
15 pin HD D-Sub (HD-15) - female
