With the Lenovo G34w, gaming is more immersive and equally thrilling. The WQHD, curved panel draws you in and places you amid the games you play. Blending perfectly with your gaming rig, a refresh rate of 144Hz coupled with AMD Radeon FreeSync technology makes for smoother gameplay that's free of screen-tearing and input lags. Low blue light certification allows for extended hours of entertainment without hurting or straining your eyes.
- Lenovo G34w-10 - LED monitor - curved - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class F
- Power Consumption (On mode)
- 26.6 W
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- 3440 x 1440 at 144 Hz
- Pixel Pitch
- 0.232 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 3000:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, DisplayPort
- Height, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100/240 V (50/60 Hz)
- Black
- 80.86 cm x 25.996 cm x 41.184 cm
- 8.1 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- RoHS, TUV Rheinland Flicker Free Certification, TUV Rheinland Eye Comfort Certification
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 34"
- Curved Screen
- Yes (1500R)
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.232 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 4 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Integrated cable management, Low Blue Light Mode, Flicker Free technology, NearEdgeless, 72% NTSC colour gamut
- Black
- 80.86 cm x 25.996 cm x 41.184 cm - with stand
- 8.1 kg
- DisplayPort , HDMI , Audio line-out (mini-jack)
Mechanical
- Height, tilt
- Tilt Angle
- -5/+22
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 26.6 W
- Power Consumption SDR (On mode)
- 26.6 kWh/1000h
- Power Consumption (Typical)
- 43 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand (lowest position) - width: 80.86 cm - depth: 25.996 cm - height: 41.184 cm - weight: 8.1 kg , With stand (highest position) - width: 80.86 cm - depth: 25.996 cm - height: 54.184 cm - weight: 8.1 kg
- Shipping Width
- 94.3 cm
- Shipping Depth
- 28.1 cm
- Shipping Height
- 48.9 cm
- Shipping Weight
- 11.3 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
